Wheel leak question
Old Jul 1, 2013 | 06:39 PM
FordFanboy's Avatar
FordFanboy
Wheel leak question
I had a slow fluid drip at the bottom of the brake drum on the inside (rear, 1976 F150 4x4). I assumed it was brake fluid, but now that I have the drum off, the cylinder looks dry. Is it the axle? Is that an easy fix?
I'll try to get some pics up.
Old Jul 1, 2013 | 06:58 PM
HIO Silver's Avatar
HIO Silver
Smell it. Does it have a hint of sulfur? If so, then it's time to pull the axles and replace the seals.
Easy is a relative term. How much wrenching experience do you have or want to learn? Do a Google search for "replace axle seal" and many return you should get. IIRC, Mustangs & Fords magazine or Mustangs Monthly has an online article.
Old Jul 1, 2013 | 07:54 PM
FordFanboy's Avatar
FordFanboy
Okay, I've got experience, just never messed with axles.
Is there anything else to do while I'm in there? Pack bearings or something?
Old Jul 1, 2013 | 09:10 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I believe since its a 1/2 ton you will have a 9" rearend and you (will) should have to tap off and back on new bearings assemblies.....
Since you are pulling the axles, you might as well do a brake job on reassembly.
Insp the axle for a grove cut in the shaft from the seal, if so there is a kit for that instead of replacing the complete axle.
Old Jul 1, 2013 | 09:22 PM
royster69's Avatar
royster69
Fanboy,
Before you get up to your elbows in wrenching, take a quick peek at the diff breather. If it gets plugged, pressure build-up can push diff fluid past the seals.
Had this happen to me...seals were fine, just the breather/breather hose needed cleaning out.
Old Jul 2, 2013 | 12:01 AM
FordFanboy's Avatar
FordFanboy
Actually, I was just about to ask about that. I noticed that the breather was stopped up and I thought I read something about that in another thread.
Old Jul 2, 2013 | 07:19 PM
royster69's Avatar
royster69
Fanboy,
Even if it is the breather (vs. seal), you'll still want to get in there and clean off the brake assembly. Your shoes could be contaminated, etc.
Good luck!
R
Amish65F100
May 8, 2017 12:08 PM
jdubsweb
Feb 29, 2016 07:28 PM
willystyle21
1978 - 1996 Big Bronco
Jun 30, 2004 07:54 PM
Cheap Monster
Jun 26, 2004 05:21 PM
