broke down going to work
Jul 1, 2013 | 07:55 AM
Ran out of gas on the rear tank, switched to the front, it died, started back up, died, then ran for about 5 miles and died. Maybe picked up some gunk from the rear tank? I hope. 85 302FI.
Jul 1, 2013 | 08:16 AM
It could be one of your in-tank low pressure pumps failed, or the filter in the tank "switching valve" is clogged (most places, including some dealers do not even know there is a filter in the 85-86 units).
Jul 1, 2013 | 08:22 AM
I have some troubleshooting tips for the dual tank system.... link in my sig below.
Jul 1, 2013 | 03:20 PM
Going to try the filter first, it would be quite the coincidence for the pump in the front tank to quit after the rear tank goes empty. A guy told me the pump on the frame goes out sometimes and costs about $40.
Jul 1, 2013 | 03:54 PM
If you need a new high pressure pump, the originals were Bosch pumps, the aftermarket replacements are noisy and don't last anywhere near as long.
Jul 1, 2013 | 05:01 PM
Filter didn't fix it. It will run for a couple minutes and die. Towing it home on a chain.
Jul 3, 2013 | 09:51 AM
On my way to the parts store, hope this fixes it.
Jul 3, 2013 | 12:15 PM
Ford said my pump is obsolete, had to get O'Reilly's.
Jul 3, 2013 | 01:23 PM
I hope it's a decent one at that price.
Jul 3, 2013 | 03:37 PM
Ran for 5 minutes, then died. No spark. It's at the mechanics now.
Jul 3, 2013 | 04:44 PM
Sounds like it might be your TFI module.
Jul 3, 2013 | 05:30 PM
Wow. Green wire going to the coil was kinda broke. Runs perfect now. $90 fuel pump, $100 for the mechanic.
Jul 3, 2013 | 05:53 PM
Ouch. Well, glad you got it sorted.
Jul 3, 2013 | 07:24 PM
Went to get pizza, truck ran fine, gave it a bath. Going to fix the rust, someday...
Jul 3, 2013 | 07:26 PM
wooot wooo dats a mighty fine specimen of a ef-one-fitty
