Sponsored by: Auxito
Gutless wonder
Old Jul 29, 2013 | 05:34 PM
BFTUFF's Avatar
BFTUFF
Originally Posted by R Pope
BFTUFF...obviously you have never been four-wheeling in Saskatchewan gumbo! If you "Stop to assess the situation" you are probably done.
I have had 4X4's for 40 years, from 4 banger Scouts to Chevs and Dodges, and never needed Low range in any of them except in hill climbing, where slow is safer.
This Ford T-case can't be shifted down at all unless the trans is in Neutral and you have the brake pedal down. That's just stupid.
Plus, when in deep mud or snow, or even buckbrush, the plastic switch on the side of the trans gets cracked and the transmission goes all weird, shifting up, down, and hitting neutral all on its own. Four MLPS switches so far, in 10K kilometers. And one transmission job. I have had it with the Blue Oval. No more Dorfs for me!
Obviously you don't know how to drive in 4 low. You can drive along at plenty of speed in 4 low D (30 mph) and switch to lower gears as needed. If you maintained your truck, it would work just fine. I picked the manual/floor shift 4 wheel drive selector for that very reason. None of the manufacturers E-shifts work perfectly.
Old Jul 29, 2013 | 05:55 PM
R Pope's Avatar
R Pope
Please tell me how "maintaining" my truck will keep the MLPS switch from shattering every 2000 miles or so...
Old Jul 29, 2013 | 10:33 PM
BFTUFF's Avatar
BFTUFF
If you don't know, I won't bother telling you.
Old Jul 30, 2013 | 08:05 PM
R Pope's Avatar
R Pope
Hmmmm...That's mature........
Old Jul 31, 2013 | 06:18 AM
BFTUFF's Avatar
BFTUFF
If your looking for a mud buggy, build one. If you insist on driving an F150 through the mud and the OE equipment isn't working well enough for you then get after market parts that eliminate those OE parts. Call that guy from the TV show: "X-treme 4x4" on PowerBlock TV TNN network. He could tell you exactly what to install to turn your truck into a mud machine. Why you want to drive in the mud is beyond me. That's a sure fire way to ruin any vehicle.
Old Jul 31, 2013 | 07:53 AM
R Pope's Avatar
R Pope
Wow! That's exactly the kind of thinking that has allowed the 4X4 to evolve into the useless hunk of junk they all are now.
I drive in the mud because I want to get out of my yard now and then! My local store is 15 miles away, 8 of which are muddy roads. Without a 4X4, I ain't goin' nowhere. And then there's this thing called "winter".......And hunting season.....Get the picture?
I have had lots of trucks in 50 years of driving in these conditions, and never one with all these electrical screwups. Sure, I got stuck, but the others would at least still run after somebody towed them out!
Guess I have to find a "real" 4X4 built back in the '70's to have something reliable. Solid front axle, manual hubs, gear drive transfer case, and a carburetor!
BTW, what aftermarket parts are there to replace the MLPS switch? Does someone make one that's metal? Because a skid plate would just hold the wet stuff up on top of it and make the problem worse.
Old Jul 31, 2013 | 06:28 PM
BFTUFF's Avatar
BFTUFF
If you have an issue call the truck manufacturers and se if they'll listen to ya, fat chance. If you've chosen to live in the boonies, then you must bare tall of the consequences that go with it and stop your bitching. Build yourself a truck or vehicle to your liking.
Old Aug 1, 2013 | 12:24 PM
R Pope's Avatar
R Pope
I bow to your obviously superior knowledge and intellect. Imagine somebody out in the boondocks expecting to get to town now and again.....the very nerve!
Although without all us boonie basher farmers out here struggling with crappy equipment, I don't know what all you pavement pounders are gonna eat......
Old Aug 2, 2013 | 02:49 AM
BFTUFF's Avatar
BFTUFF
Pavement my ***. I live in Northern MN and can at my choosing run across any kind of terrain you can think of. In-fact, I was out in the woods today and decided to exercise the OE 4 wheel drive manual shifter in my truck as I do often to keep it in good working order. I put it in 4 low and left it in drive (D). I was able to drive comfortably at 35 mph with loads of power. My 98' has 200,400 miles and is getting tired: less power and milage than a few years ago. In 4 low, I had all the power I could ever need. Once I slowed down and dropped it into 2nd I could go anywhere my tires would bring me if I'd chosen to. I didn't even bother with 1st because I would have gone through the window with the amount of power available there.
When I looked for a truck, I specifically chose the manual floor shift for the same reason your having trouble with yours. Because it eliminates one more electrically (weak) operated part of the 4 wheel drive system. All you have to do is keep it lubricated and it works great. I grew up with Jeeps and know the value of a reliable drive-train. Do some research and you will find an after-market solution to that ESOTF BS switch. Go out and put your truck in 4 low and D and try again, 2nd if necessary. Give it a try and reply. Note: you'd better have some good tires if your driving through that kind of material or all the power in the world won't help you.
lettereat
1997 - 2003 F150
20
Jan 30, 2009 10:00 AM
c_cort
1997 - 2003 F150
47
Oct 17, 2007 09:24 AM
uarep
Apr 17, 2007 03:03 PM
billboy36
1997 - 2003 F150
Mar 11, 2004 08:10 PM
jswanberg10
Aug 8, 2003 05:45 AM
