Vermont July 2013 BS thread - independence from overpowering government and deep BS
#1846
#1849
on
The old taillights are so dark you can barely see the lights through them. And they are mounted very low, below the ramp. We're replacing them with LED's, one half way up the left/right sides and two more where the old lights were. Will give far better visibility to people behind me.
Tracing the wiring isn't rocket science, just time consuming. Got to pull the access panel off to find the igniter controls.
And there aren't as many sheep as there used to be
Hi Shawn. No you had it right
#1855
Water heater is now working on gas. It's the little things that make your day.
Wasn't complicated once I did a bit more digging. Fridge works, water heater works, all the stove burners work, gas station works, generator works, both AC's work, TV, DVD, stereo all work. Only thing left to check out is the water pump for when or if we dry camp. And if it doesn't work the PO left me a brand new one to replace it with. Apparently the one in the RV now was a little fussy so he had a new one ordered but then the old one started working again.
Life is good.
Life is good.
#1858
Life is good.
Life is good.
Evening Shawn!
You're having a better day than you thought.
