what would be a ideal set of wires and coil for a 351m with msd 6a ignition and whats the best plugs.. ive rebuilt motor above stock cam.had to shim rockers . alumium intake and holley 4 barrel
Motorcraft or Autolite plugs and coil. Motorcraft wires. The aftermarket stuff does not last as long. Looks purdy tho.
Stick with the stock Motorcraft ignition module. If you have a problem with the MSD it is hard and $$ to get a replacement and it is sometimes difficult to get one tested at the parts store. The Motorcraft ign module has a retarded ignition timing function for easier starts also. The Motorcraft module is available at most parts stores. Mount it 1/4" off of the fender with spacers to allow cooling air under it.
