Australia Chapter Join Chapter , Leader: ChunderDownUnder
Speedo recalibration
Old 07-16-2013, 07:32 PM
ChunderDownUnder's Avatar
ChunderDownUnder
ChunderDownUnder is offline
easy. just go into tyre size and bump it a bit then go for a drive and check against your navigator gps speed. Im running 35's and I think a went up to 34 in AE and that got me within 2kph against the gps.
https://www.ford-trucks.com/forums/9...-question.html
there is a PDF link in post#4
Old 07-16-2013, 08:04 PM
Aussie BrianB's Avatar
Aussie BrianB
Aussie BrianB is offline
Brian,
Once again many thanks for the info.
Old 07-18-2013, 06:38 AM
Patchy 73's Avatar
Patchy 73
Patchy 73 is offline
Brian,
Just curious what RPM are you getting on the alledged 100 kmph
Cheers,
Patchy
Old 07-18-2013, 06:48 AM
Aussie BrianB
Originally Posted by Patchy 73
Brian,
Cheers,
Patchy
I did not pay attention to RPMs, not used to having a
tacho, I'll have to check that.
Are you wondering if the diff ratio has been changed?
Old 07-18-2013, 07:17 AM
Patchy 73's Avatar
Patchy 73
If the diff ratio has been changed it puts a different spin on things
My truck is stock standard and about 1800 rpm is 100 kmph
Cheers,
Patchy
Old 07-18-2013, 07:26 AM
Aussie BrianB
Cheers,
Patchy
Thanks.
There is no evidence that any work has been done on the diffs.
I will check the tacho next time I have the truck out for a run.
Old 07-18-2013, 07:42 AM
Patchy 73's Avatar
Patchy 73
Why i ask i'm running simular tyre size you are, and to me, to be out by 12kmph seems to be alot to me if everthing is stock
Cheers,
Patchy
Old 07-18-2013, 08:04 AM
Patchy 73's Avatar
Patchy 73
Oh Well, give it a run the open road
I still like to know what the rpm is
Cheers,
Patchy
Old 07-18-2013, 02:54 PM
ChunderDownUnder
Cheers,
Patchy
1800 Im about 105 Kph
Old 07-18-2013, 03:17 PM
BigF350's Avatar
BigF350
BigF350 is offline
At 1750 I am bang on 100kph, but I have a manual (.72 top gear, instead of .71 in the auto) and 275/70R18's (a little bit smaller than your 315/75R16's)
IIRC, changing the diff ratio in these won't correct your speedo, as it reads off the wheel speed sensors.
Old 07-18-2013, 04:19 PM
Nkelly's Avatar
Nkelly
Nkelly is offline
Farkall User
ABS ? ya mean.
Im going to change my diff ratio's,i think brian said we have 3.73 gears,not sure what the next lower ratio is 4.11 ? but that's where im going,dont like my trucks response and fuel consumption now that I have 35's on.
Old 07-18-2013, 06:03 PM
BigF350's Avatar
BigF350
BigF350 is offline
Yes, ABS sensors.
4.10 is the next ratio (it's just the pinion teeth number that change).
I don't have first hand experience, but doubt 4.10's will improve your fuel consumption.
  #28
Old 07-19-2013, 05:09 PM
Nkelly's Avatar
Nkelly
Nkelly is offline
Farkall User
Yes, ABS sensors.
Its gotta around town,open road @ 100kmh's prob not,i reckon ive gone up 3 ltr's per 100 since I went from stock rims and 31's to these 35's..
Im going to take these 35's off and stick my stock rims and tyre's back on and do a fuel consumption test,i'll let you know.
Atm im doing 18.5 ltrs in 80E and I drive it like an ol lady
  #29
Old 07-19-2013, 05:16 PM
ChunderDownUnder
just checked again. 1800 rpm is 108kph (70mph). And Im the same with the fuel when switching to 35's and 5" lift. I have gone from mid to high 15's per litre to mid to high 17's. 18's when Im dragging anything that looks at me
Bruva 4.10's is the next step. But i would do some research. Alot on Powerstroke Army say and dont do squat.
  #30
Old 07-19-2013, 05:19 PM
ChunderDownUnder
Thats what AE does with the tyre size calibration. It adjusts the sensors.
Quick Reply: Speedo recalibration
