easy. just go into tyre size and bump it a bit then go for a drive and check against your navigator gps speed. Im running 35's and I think a went up to 34 in AE and that got me within 2kph against the gps. https://www.ford-trucks.com/forums/9...-question.html
there is a PDF link in post#4
At 1750 I am bang on 100kph, but I have a manual (.72 top gear, instead of .71 in the auto) and 275/70R18's (a little bit smaller than your 315/75R16's)
IIRC, changing the diff ratio in these won't correct your speedo, as it reads off the wheel speed sensors.
ABS ? ya mean.
Im going to change my diff ratio's,i think brian said we have 3.73 gears,not sure what the next lower ratio is 4.11 ? but that's where im going,dont like my trucks response and fuel consumption now that I have 35's on.
4.10 is the next ratio (it's just the pinion teeth number that change).
I don't have first hand experience, but doubt 4.10's will improve your fuel consumption.
Its gotta around town,open road @ 100kmh's prob not,i reckon ive gone up 3 ltr's per 100 since I went from stock rims and 31's to these 35's..
Im going to take these 35's off and stick my stock rims and tyre's back on and do a fuel consumption test,i'll let you know.
Atm im doing 18.5 ltrs in 80E and I drive it like an ol lady
just checked again. 1800 rpm is 108kph (70mph). And Im the same with the fuel when switching to 35's and 5" lift. I have gone from mid to high 15's per litre to mid to high 17's. 18's when Im dragging anything that looks at me
Bruva 4.10's is the next step. But i would do some research. Alot on Powerstroke Army say and dont do squat.
Thats what AE does with the tyre size calibration. It adjusts the sensors.
