Electrical/ Battery issue
Old Jun 29, 2013 | 01:12 PM
bb612's Avatar
bb612
Truck needed a jump Rocket Scientist hooked cables up wrong and burned them up. Did get truck started and ran for about a day. Cranked it up and it died. Replaced batteries (they needed it anyway) have 14 volts, when I try to crank engine volts drop below 10 and truck won't crank. Have checked ground wires and fuses, just doesn't seem to get enough juice to crank. Even tried jumping it with a service truck that had 3 batteries. Anyone have any suggestions????
Thanks
Old Jun 29, 2013 | 02:44 PM
dannyboy950's Avatar
dannyboy950
Did you replace all the burned up wires from the backwards jump.
Sounds like a high amp draw to me.
Old Jun 29, 2013 | 04:42 PM
bb612's Avatar
bb612
The only wires that showed any burning were the battery jumper cables, none of the other wires showed any sign of being burnt.
Thanks
Old Jun 29, 2013 | 11:32 PM
04badford's Avatar
04badford
I beleave your batteries were toast before the jump IDK, you can test each batt separate and see what you have 14vand I would replace both in pairs, also check the FICM that has to stay 48+ for good Injector health if the FICM is below 45 give Eds ficm repair a call, as far as jumping wrong way we need one of FTE techs to chime in about what damage this could bring to some or all of these componets. Stay Tuned
Bowtie_Schmowtie
Mar 19, 2018 06:05 PM
SPD&PWR
Sep 7, 2013 05:50 PM
andym
Feb 1, 2010 07:42 PM
78FordF2504X4
Electrical Systems/Wiring
Jul 6, 2006 01:55 PM
justdan
Apr 4, 2005 09:27 PM
