Oil Filter Messy During Change
Some people have reported success punching the filter, but I have tried punching it several ways with no success at all. I've taken a sharp landscape timber nail and driven it 5" up into the filter and still had a mess when I unscrew the filter. I've tried waiting 30 minutes after punching the filter and still not prevented the mess.
I've given up and just man up, unscrew the filter and let it run all down the sides of the filter until it has had its fun. I got more oil on myself trying to punch the damn thing than I do if I just let it drain itself and then remove it.
Yesterday I lost my grip on the filter as it came off and it went kerplunk (technical term) into the collection pan. That was just lovely.
I had the same issue on my '93 and wish FoMoCo had addressed this.
I assume everyone has the problem I have - that as the filter is unscrewed it starts to leak. Then as it is removed further more oil leaks out.
I've been using paper towels wrapped around the filter to enhance gription, (TT, again) but that didn't work well this time.
There HAS to be a fix.
on
I use a 5 gallon bucket under the oil pan and another 5 gallon bucket just beside it under the filter. I just unscrew and let it fall into the bucket and then it drains by itself. If you spin it off fast it won't have a chance to really coat the outsides of the filter making it difficult to grasp.
There's no good clean way to change any spin on filter, unfortunately. 720deere is right, just break the seal and let it drain out. I break mine loose and then give it a spin so it unthreads a bit, helps it drain faster. I consider it a bonus when you can drain the pan and filter into the same catch pan.
Yes, it's hard to hold on to it, I've dropped it a couple times.
What I do is wear rubber gloves, place a hotel sized (got mine from a days inn) garbage can under the filter and unscrew it halfway, it drains for a few minutes, then I take it off and dump it over into the trash can, trying not to drop it.
I use a short 5-gallon bucket for the oil drain too, if you have one big enough it will catch the oil from the pan and the filter. I do this sometimes too, easier to deal with just one bucket to clean up.
If you catch things right it is possible to change the oil and have two or three little drops on the ground and oil soaked rubber gloves.
Epics video is great but like many I have not had success with punching either, perhaps the punch needs to have a larger diameter to make it successful.
I use a 5 gallon bucket also for draining the pan but under the filter I use an aluminum foil roasting size pan that can be tossed when you're done with the oil change. I pour the oil that's in the pan into the 5 gallon bucket then fold up the pan and dispose of it.
Another trick is to put down some heavy mil plastic sheeting and drive over it for that time when things go wrong - like dropping the oil filter. I pre-cut sheets about 6' x 6' and have them ready to go.
Hope this helps.
Hope this helps.
