96grimreaper's 01 F250 Platinum build.
#47
I always liked the rear clearance lights, gives the truck a bigger look. These things are bright, so bright I might have to add led tag lights. Also considering mounting some led reverse lights in the gap between the bumper and tail lights.
You definitely should put them on your X. If I still had mine it would have got them too.
#48
#49
I wish I had some pics but all I have is the camera on my phone and it does the lights no justice.
All 4 are spot pattern. When I bought them for one of my other trucks I was driving about 45 minutes at night on back roads home so I needed much more light down the road.
I've had halogen, converted 35w and 55w hid and factory hid off road lights and for the size, range and pattern the Rigid led's have, I'll stick with them. When funds are available I'm going to go with a 20" spot/flood combo in the bumper. I'm also either going to go with the flush mount SR-M diffused or a single dually with diffused lense for extra reverse lights.
#51
I just acquired my father's 01 Powerstroke and I want to convert from the old sealed beam headlights to either the ones you did or the black 05 headlights...but every time I research the composite lights you have it states *not for use with sealed beam models* is the wiring different? Or is it plug and play regardless? Just curious how intensive the project is going to be when I switch.
I know the 05 headlights require some cutting of the header panel which doesn't seem like that big of a deal if you are already in their dong the swap.
#52
#53
The reason they say not for sealed beams is because the two are different, i am not sure about the wiring but i cant imagine its hard to switch the socket type its only 3 wires. If you want to go with like what grim has then i believe its an easy switch. As easy as removing the sealed beams and installing regular lights. Ford often times makes the same panels and just adapts housings to fit. In the instance of the 05 lights the socket is a 9008(H13) socket not 9007 like the 99-04 trucks so personally pick which one you rather have and then cut and solder the correct plug on and install your new lights. 05 will require cutting and 04 shouldn't someone may jump in and correct me on that if i am wrong. Also if you are going to go through with an 05 headlight i would recommend getting a relay harness because it will increase your light output or go with HID's but aim them down to not blind people.
#55
Thanks for the reply. I like the looks of the 05 headlights better. I have found several sets on ebay that come with a premade harness to adapt from the 9007 to the H13 so that part should be simple. I suspected that the warning was simply for people looking to replace one headlight (one composite and one sealed beam would not be a good look). I was not aware that the 05 headlights increased output...would it be an issue if I did not do a relay harness? I have gone the HID in stock reflector housing thing before and I would like to avoid going that route now. I think some Silverstar Ultras would work just fine for my needs. Anything would outperform these sealed beam units at this point.
#57
#58
#59
Agreed! What are you going to use for the winter prep? I should probably do the same...looks like my garage is getting cleaned out and my moms car is gonna be in the driveway .
#60
