Sponsored by: Real Truck
F350 Capacity Question
Old Jun 25, 2013 | 10:52 AM
Lndeatr1's Avatar
Lndeatr1
Hi all,
I have a 2003 F350, crew cab, 4x4, long bed SRW with a 7.3. I put X codes on the front and C codes and firestone bags on the rear. Originally had B/V springs. Does anyone have the specs for weight limits for a truck that came from the factory with X/C springs? Just upgraded my 32' Cougar for a 37' Cyclone toy hauler so we can take the Harley and lock the kids in the garage at night. Tows great but according to the orginal Ford Specs, I am pushing/maybe over the limit. love my 7.3 and wouldn't give it up.....
Old Jun 25, 2013 | 11:09 AM
ken kenmnedy's Avatar
ken kenmnedy
no matter what you do to the truck you are bound by the sticker from the manufacture that's what the d o t man will hold you to
Old Jun 25, 2013 | 11:19 AM
Lndeatr1's Avatar
Lndeatr1
Ken, totally get that but am looking to see what the actual difference in functionality is.
Old Jun 25, 2013 | 11:28 AM
bunklash's Avatar
bunklash
Welcome to the forum. There are tons of posts on this topic. The short answer is to look at your door sticker for capacities. Adding airbags, springs and such doesn't raise your capacities, just improves the ride.
There are a few different things to consider, but the one that's gonna limit you the most is your pin weight. And the only accurate way to know where you stand is to visit a weigh station.
You more than likely are overweight with such a big toy hauler. Many, many rigs are out there overweight. The issue is by how much and how much risk tolerance you have for your's and other's safety.
To learn more, do a search here. There is also excellent info at RV.net
Old Jun 25, 2013 | 11:45 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by Lndeatr1
Hi all,
Here is an example of a VB door sticker. Like all F-350 SRW trucks of your vintage....the GVWR is 9900 lbs irregardless of what spring pack was listed. So, changing to XC springs will still yield the same 9900 lb gross vehicle weight rating.
FAWR and RAWR are determined in large part by the tire pressures listed on the door sticker. The max RAWR is 6830 because LT265/75R16E tires are rated at a max of 3415 lbs @ 80 psi.
The spring code determines the ride height and deflection rate. In regards to load carrying capacity, the axle is not the limiting factor, the physical capacity of the axle is far greater than the load index of the tires (even at full psi inflation).
Old Jun 25, 2013 | 12:05 PM
Shake-N-Bake
Hi all,
I towed my neighbor's 36' toy hauler up to the mountains this past weekend. It only weighed 12,400 lbs. Total GCVW at the scale was 20,100 lbs so that wasn't too bad actually. Pin weight was well within the capacities of a 350 SRW truck...(although my truck is only a F-250).
I recommend you get your combo fully loaded for travel and then get weighed at a certified scale. Use a scale that measures the front axle, drive axle and trailer axles separately. Then drop the trailer and go back through the scales with just the truck. The re-weigh should run about $1 or so...
With this info, you will be armed with accurate info to access your actual situation.
Brett W 55 Ford
May 4, 2012 05:25 PM
daveroderick
22
Apr 7, 2012 04:16 AM
FORDF250HDXLT
16
Oct 6, 2009 05:25 AM
AusDually
Jan 22, 2009 12:45 PM
