I got a 95 f250 7.3 4x4 single can long bed. Just put a Dana 60 up front and 4inch turbo back exhaust kit from mbrp. I used to get around 14 mpg. But ever since I did those things it's dropped to 10.5. Any reason why it would do this?
Are all the bearings and hubs good in the D60? Could be out of alignment, or have a caliper sticking a little. Make sure the 4x4 hubs aren't engaged. Do you keep your foot in it now to hear that new exhaust? LOL! That will do it for sure! LOL!
All new hubs calipers rotors pads ujoints and ball joints. Hubs are free. No I don't. It's been like this the last 3 tanks of diesel. Same commute nothing new driving wise
Rear brakes dragging maybe.i had a bad parking brake cable holding a brake on...its prob not your problem but throwing it out there
also.what springs did you use front and rear.im windering if big lift maybe wind resistance...i know thats a strech but..
Did you get the new axle aligned after you installed it? With as much weight as there is sitting over the front axle on these trucks, the front end alignment makes a big difference in the rolling resistance of the truck.
