Getting ready to do brakes!!!
Old Feb 21, 2011 | 12:19 AM
mustanginca's Avatar
mustanginca
Haven't done brakes since I owned it. I figure it's time. Just wondering if there are any special tools required? Its an f250 7.5l 4x4 Dana 50 TTB up front. Manual hubs. I wanna change out the rotors too. Heard that was the tricky part.
Old Feb 21, 2011 | 12:57 AM
Cory281's Avatar
Cory281
Brake pads are easy, to get the rotors off you have to remove your hubs. If you can do that then you're good to go.
Old Feb 21, 2011 | 02:03 AM
mustanginca
Any trick to getting the hubs off? I've done brakes a few times just not hubs.
Old Feb 21, 2011 | 02:07 AM
mustanginca
https://www.ford-trucks.com/forums/s...d.php?t=176787
Found it hopefully.
Old Feb 21, 2011 | 04:15 AM
Lazy K's Avatar
Lazy K
That link is good for getting the locking hubs off, once you have them off you will need the D50 bearing retainer socket to remove the spindle locknut. You can then slide the hub, rotor and bearings off of the spindle. You then need to press or hammer the lugs out and the rotor will come apart from the hub.
Old Feb 21, 2011 | 05:02 AM
mustanginca
Sounds like a pain. How are the powerstop rotors? I can't find any reviews of them. I like to order from summit and that's a brand they have.
Old Feb 21, 2011 | 07:11 AM
Lazy K's Avatar
Lazy K
It reads worse than it is. Once you do the first one the second is easy.
No experience with Powerstop so can`t give you an opinion.
Old Feb 21, 2011 | 09:20 AM
mustanginca
Thanks for the info
Old Feb 21, 2011 | 01:56 PM
carolmryals's Avatar
carolmryals
You should be fine with this list:
* lug wrench
* c-clamp
* open end or adjustable wrench (depending on your car)
* Allen wrenches (depending on your car)
* hammer
* small bungee cord
Btw what about brakes, did you find some good quality ones? Recently I talked to a mechanic that specialize in brakes He said that wagner brakes pads are very very good. I though to get with Wagner Brakes next time when changing mine.
Old Feb 21, 2011 | 05:22 PM
mustanginca
Im going with summits power stop cross drilled rotors and their pads. Always liked summits service.
