2011 F250 2" Leveling Kit PROBLEM
I did my level kit as well. It's not right and I'd bet money either the rubber isolator or the spring is not indexed correctly. You can look at the bottom of the spring perch to be sure if its the spring or not. If there is space between the spring and the bump stop for it it needs indexed. Post a pic of the bottom if you're not sure.
on
There's a polyurethane rubber washer disc that is missing from the top of the spacer and the mount. Yeah like other said the spring should be set in and then rotated clockwise (looking down on the axle spring mount from above) until the end of the coil is right up against the stop.
Even if the kit doesn't specify that urethane piece I'm not sure why you would want to have metal on metal contact there. Notice the OEM frame mount doesn't have a perfectly flat surface.
I have an 07 same frame and axle and I bought cage aluminum 2 1/2 spacers they fit perfect. They are also the same outside diameter as the spring which I like. You will need an adjustable trac bar now. Your axle will be off center if you look at it. If I buy a 13 im keeping my cage blocks, company went out of business and nobody makes solid aluminum spacers anymore.
SUPERDUTY_08
6.4L Power Stroke Diesel
12-14-2011 01:27 AM
stebab
1999 to 2016 Super Duty
08-16-2009 07:00 PM
