Sponsored by: Real Truck
A/c. Recharge
Old Jun 20, 2013 | 04:56 PM
Tony Mongelli's Avatar
Tony Mongelli
Thumbs up A/c. Recharge
Where is the low side hook up to charge my a/c 2003 f250 v10
Thanks
Old Jun 20, 2013 | 05:58 PM
projectSHO89's Avatar
projectSHO89
Go read the HVAC FAQs. Link is in signature.
Old Jun 23, 2013 | 02:12 PM
Tony Mongelli
Was told a/c clutch was burnt out, can you just replace the clutch head??
Thanks, any info would be great
Old Jun 23, 2013 | 02:19 PM
JWC 3's Avatar
JWC 3
The low side hook up is at or near the dryer .
Old Jun 23, 2013 | 02:20 PM
JWC 3's Avatar
JWC 3
Yes . you can , if avalible .
Old Jun 23, 2013 | 02:50 PM
Tony Mongelli
Thanks , is there a link u can lead me 2 on replacing the clutch head on that a/c 2003 v10
Old Jun 23, 2013 | 03:02 PM
JWC 3's Avatar
JWC 3
I'm not good at links . But it is a fairly straight forward job . Small bolt in middle ,pull plate and shims , shims are real small , don;t loose them . Snap ring . Tap off hub/pulley then electro magnet . Reverse to install . just be sure your air gap is correct . As a mater of fact , ck your air gap first , That may be your only problem . You change the gap by removing or adding shims .
bulred
Modular V10 (6.8l)
Aug 29, 2015 05:28 AM
Kfagan2012
Apr 7, 2013 07:14 PM
riverratmike
Aug 30, 2010 06:41 AM
redsford
Aug 16, 2007 09:00 PM
windyhill
Jul 15, 2006 10:02 AM
