i just cant win,, help.....
Old Aug 22, 2013 | 06:09 AM
  #46
Area351's Avatar
Area351
If you have good compression in those cylinders, you don't have burnt or sticking valves. That would show up on the compression test with a very low (or no) reading on those cylinders.
If you have, fuel, spark and compression and it still doesn't fire, your cam timing is off.
Old Aug 22, 2013 | 04:02 PM
  #47
JEFFFAFA's Avatar
JEFFFAFA
I don't mean to insult you but, since they are right next to each other could you have the plug wires switched? 13726548.
Old Aug 23, 2013 | 04:22 PM
  #48
351Cleveland C4's Avatar
351Cleveland C4
no offense taken jeff, I thought of that myself and checked it a couple times. they are correct.
area351, thats what I thought, so the valve possible still dosent explain it,
if the cam timing was off wouldn't the other 6 cylinders show some indication of it as well? even running on 6 cylinders ive got a good amount of power coming down....
craigerF100, its a GM HEI style distributor, the points got the boot...
heres another possible pointer, I swapped in 2 brand new plugs into 7 and 8 and ran them for a little bit, when I pulled them back out they were just as clean as when I put them in, there were absolutely NO deposits or oil/gas on them. this leads me to believe that there isn't any fuel getting to them.
Old Aug 23, 2013 | 06:20 PM
  #49
JEFFFAFA's Avatar
JEFFFAFA
What?! A pluged intake? Did something nest in there while you were building that motor? As I recall you are using a dual plane intake. That would mean 7 and 8 would be fed from the 2 different barrels of the carb.
Old Aug 24, 2013 | 02:30 PM
  #50
351Cleveland C4
yea jeff that's right, factory dual plane intake fed by both barrels, I took the intake off and it is CLEAR. no obstructions of any kind...
so I ask ya, what the heck is going on here?????????????????????
Cowboybrad351
Feb 6, 2019 12:19 PM
Dustin_in_PDX
Oct 14, 2017 05:51 PM
JRB64
45
Jul 22, 2017 03:54 AM
shannonguy
Jul 7, 2014 08:31 PM
mktsc
22
Dec 16, 2011 12:50 PM
