...New Engine?
Old Jul 15, 2002 | 07:26 AM
mike90sc's Avatar
mike90sc
...New Engine?
Hey Guys,
After finally finding the oil sending unit thursday night, I discovered there is a special socket to get the oil sending unit out. Swapped it out and still I los oil pressure within 1 mile of driving. Every time you hit the gas, pressure instantly drops. Now, it also runs real rough. Idle varies between 500 and 1200. Within the last 3,500 miles, I replaced IAC, EGR, TPS, plugs, wire, PCV, and air/breather filters. The exhaust smells nasty and it also has no power. I ckecked oil and it is clean. Am I looking at having the bottem end of the engine rebuilt? I am feeling pretty sure that the oil pump may have gone out in it. But Ialso wasn't sure if I had a head gasket go (internal leak?) or if the computer has croaked. I had the shop come and get it becuase I didn't want to make a bad situation worse by driving it. Any thoughts are greatly appreciated. In case you missed my first post it is a 90 F150 XLT Lariat 4x4, 5.0, AOD, with 118,000 miles on it. Truck has been well maintained with 3,00 tp 4,000 mile oil changes. I have been using Valvoline Maxlife 10W30 and Bosch oil filters. Thanks!
Mike
Old Jul 15, 2002 | 09:14 AM
oregon250's Avatar
oregon250
...New Engine?
[updated:LAST EDITED ON 15-Jul-02 AT 10:15 AM (EST)]Go and get a compression test done on each cylinder and have them check your cooling system for leaks. This isn't that expensive and may save you a couple of thousand if you don't need a new engine.
Geoff
1993 F250 4X4 460cid (7.5l)
Old Jul 16, 2002 | 07:22 AM
mike90sc's Avatar
mike90sc
...New Engine?
Yeah, that is part of their diagnostics. This shop is usually pretty decent. I haven't heard from them yet, so I will post the results when I hear...
Mike
Old Jul 17, 2002 | 01:18 PM
sixcar's Avatar
sixcar
...New Engine?
Try a new oil filter. In some rare cases, the oil filter bypass may stick open. Otherwise, make sure you have strong vacuum to the PCV valve.
Good luck.
Old Jul 17, 2002 | 01:36 PM
hitecdan's Avatar
hitecdan
...New Engine?
