Every old truck...
Old Jun 17, 2013 | 08:03 PM
1983F1503004x4's Avatar
1983F1503004x4
Every old truck...
... has whistling mirrors. I haven't been in an old truck that doesn't.
So, my question for my fellow FTE'ers today is, "Is there any way to get the blasted things quiet?"
The only noises my truck makes going down the road are the exhaust and the constant, nagging whistling from those old mirrors.
Old Jun 17, 2013 | 08:21 PM
Franklin2's Avatar
Franklin2
I doubt it's the mirrors. The only trouble I have ever had was with leaky weatherstripping around the windows, and loose trim around the windshield.
Roll down the windows and see if it goes away. This is not a common problem with these trucks, and Ford would not have sold them with noisy mirrors, loose steering, etc.
Old Jun 17, 2013 | 08:56 PM
1983F1503004x4
Mine's definitely the mirrors. Vent windows closed, crank windows down, and 55 mph makes for some noisy mirrors.
You can put your hand around the base of the mirror and the sound changes. Dunno why mine whistle, but they do.
Old Jun 17, 2013 | 09:04 PM
oneowner83's Avatar
oneowner83
Mine have never made noise either, but I dont drive over 65
Old Jun 17, 2013 | 09:30 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Mine don't whistle either, but then mine are the factory trailer tow mirrors. In fact my truck is almost quiet inside. You do get some exhaust drone at certain rpm, but not really bad.
Old Jun 17, 2013 | 11:24 PM
Fordzilla80's Avatar
Fordzilla80
If you want to fix the whistling mirrors, you just have to weld your D44 beams together.
Old Jun 18, 2013 | 01:28 AM
joshofalltrades's Avatar
joshofalltrades
try buying a different pair of mirrors from your local parts store, it could just be that your mirrors have a funny shape on the backside that does funny things with the wind. or be a real bad-a$$ like me and have double mirrors on both sides
its likely that any change at all will kill the wind noise, even like guys with roof racks might get a noise, but it goes away if they move the rack even just an inch
Old Jun 18, 2013 | 05:17 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Are they factory mirrors or repops? My 86 had the factory mirrors and never whistled.
Old Jun 18, 2013 | 09:52 AM
1986F150six's Avatar
1986F150six
No cost experimentation!
By putting your hand around the base of the mirror, you are changing the airflow, not only around the mirror, but for everything after the mirror.
Do you have a camper shell or bed mounted toolbox? Have you tried changing the position of the mirror? If you have swing-a-way mirrors, adjust the one on the passenger side to where it is parallel with the body and see if the whistling changes.
As was mentioned previously by Franklin2, it might be the trim around the windshield. Take some blue painters masking tape and seal the trim edges and see if the whistling diminishes. The tape can be easily removed, if not left on too long. This is a bodyshop trick. Sometimes they even tape the seams of hoods, fenders and doors in their hunt for wind generated sounds.
Good luck!
Last edited by 1986F150six; Jun 18, 2013 at 10:00 AM. Reason: Added toolbox question.
Old Jun 18, 2013 | 09:59 AM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
Mine don't make any noise at all
Old Jun 18, 2013 | 11:02 AM
emgee's Avatar
emgee
I think these trucks came with an additional door seal at some time as an option and later became standard. That seal would be along the front post (against the "A" pillar on over the top of the window and slightly down the rear post. My 1980 has one door seal but my newer 1992 doors are like this. I don't know when this extra seal change occurred. Look at a newer truck in a JY to see what was done and you could replicate it with a pressure-sensitive adhesive closed cell foam strip.
Old Jun 18, 2013 | 10:13 PM
ctubutis's Avatar
ctubutis
I don't know that it ever became standard, but, the way I remember 81-F-150-Explorer (where's he been for the past several months?) explaining it....
The "inner" seals are for water and all variants had them.
If an optional Sound Reduction package was ordered, the "outer" seals were added.
Old Jun 18, 2013 | 10:27 PM
WilleyJoe.62's Avatar
WilleyJoe.62
Ford offered the RRV (Rural Road Version, sometimes referred to as the "Country Boy Package", or CBP) on a limited number of '86 trucks. The RRV included the DCS (Deer and Cow Safety) mirrors, which emit a high-pitched whistling sound at speeds over 45 mph. Very rare.
Old Jun 19, 2013 | 08:11 AM
85lebaront2
WilleyJoe.62, that's a hoot, you ain't right in the head boy.
That puts in proper CBP lingo.
Old Jun 19, 2013 | 09:18 AM
1986F150six
I can't figure out if I should rep WilleyJoe.62 or not?
