I was told by a Ford Mechanic the first letter represents the decade, the next being the year. This casting sequence started in the 40's so C3 equals 1963.
I read in another posting that number represents the identification for the block only and you would have to measure the stroke to figure out the size of the engine.
I knew the numberdummy would get to the bottom of that, Thanks for not making me look as bad as my answer.
Bill, I changed the starter the other day and got the numbers from underneath. They are from my 66 Flareside and the replaced engine.
The hidden numbers are EOAE D3C00 4B20.
I was told at the parts store' it appears to be a 302 from a 1980 bronco however you mentioned (without the numbers) it could be a Windsor. The Manifold is an Edlebrook so I'm still having trouble identifying the engine
Could you or someone confirm from this info what it actually is. Thanks in advance
Hey you guys are Great. The best part is that with all the knowlege you guys have, you still have the patience to answer green questions. that's good because Im sure Ill have more.
l dont want to butcher the 65 to make the 64 223 fit. i suppose the search is on for an engine and tranny again. The 64 still has a functional drive train so it may have to tear up the organ donor card.
Thanks, Dennis
Parts for the 1965/1966 motors are fairly readily available. For a 1965 F100, if it came with a 6 cylinder, then it was likely either a 240 or 300 cubic inch "big six".
Thanks that's what I'm in search of now and if it has a 3 speed trans bolted to it even better.
If anyone in Southern California has an engine and trans and willing to get rid of it let me know.
