Sponsored by: Real Truck
Spring squeek / ? plastic inserts
Old Jun 17, 2013 | 07:53 AM
prorad's Avatar
prorad
Hi all -- Noticed at the end of winter this year getting a pretty good squeek from the springs - believe it is the rear more than the front. Contacted my local Ford dealership -- the OEM plastic spring inserts are avaliable -- has anyone done this before, and/or any suggestions? Thanks!!
2001 F250 SD 4x4 6.8L
Old Jun 17, 2013 | 09:05 AM
northwindone's Avatar
northwindone
You are in luck. An FTE member known by the user name 1975StroppeBaja has done this repair and has documented the repair, along with many others, on the Super Duty tech article portion of his website....
2004 F250 Squeaky Leaf Spring Fix
Old Jun 17, 2013 | 10:21 AM
SuperDutyScaler's Avatar
SuperDutyScaler
ive changed mine twice in the 111k i have on my truck but i would never buy them from the dealer TOTAL RIP OFF! I go to a local spring shop and pay $1.00 a piece for them. In the rear i put a 4ton jack and a piece of 6x6 under the hitch and lift the suspension so the tires are just almost off the ground, then i use my brass wedge and hit it between the leaf i want to separate and pop the old one out and push the new one in, be sure to swear a little grease on the new spring pad. Shouldnt take you more than an hour tops
Old Jun 17, 2013 | 07:03 PM
prorad's Avatar
prorad
Thanks for the information -- Greatly appreciate it!!
Old Jun 17, 2013 | 07:05 PM
prorad's Avatar
prorad
.......... and you are right --- buying from the dealer is a total rip off --- quote for plastic inserts: $47 per spring!!! $188 for all four, plus tax....... and God only knows what they would charge for installing!!! Ugh!!! Thanks all!!
Old Jun 19, 2013 | 12:39 AM
DND58's Avatar
DND58
I also have the squeeky front end. In one of Jasons(1975StroppeBaja) posts, he mentions that the 1C3Z5B302-AA kit would not work on his 2004. If I get this right, that kit works for 99-2000 trucks. Later than that you need the 2C3Z-5586-AA kit.
Can anyone confirm that?
wigpro
Modular V10 (6.8l)
Apr 27, 2014 08:32 PM
AK FORD GUY
Nov 7, 2010 07:36 AM
togobefastguy
Apr 23, 2010 01:21 AM
togobefastguy
Jun 9, 2009 12:04 PM
EOD
Feb 14, 2003 11:55 AM
