IH water pump filter, LOOK!
Well folks, anybody in doubt of the need for a coolant filter? I bought the mare with 172K on it and when I did all the mods to it I put a IH water pump on it. I wasn't happy with the way it was staying cool so I thought I would do three things to it before taking off again. Change the clutch fan, drop the rubber protector thing on the bottom of the bumper down making a air scoop and change the filter. The filter your looking at has only 3,500 miles on it! The picture of my air scoop is terrible but maybe you can get the idea. I used bolts and a board creating a gap of a couple of inches to help get more air into the radiator, 6.0 trans cooler, IC, a ac condenser.
I'm so close to ordering one and doing it but there various write-ups leave a lot to the imagination. Makes me nervous I'll get stuck. Guess I better go ahead though after seeig these pics.
Ya Gabe & Darin, I'm also glad I put one on. I cut one open on the mule after 10K miles and it didn't look that bad. I hope that doesn't mean anything about the mare! Dan, Gabe is right, its just a matter of getting a few things together. The bolts I got at Lowe's, short stem thermostat, cummins lower radiator hose and a couple of fittings.
There are a lot of kits out there and a lot of threads about installing one. The one I have is built into the International water pump. Doesn't matter, the important thing is to put one on, it saves you the trouble of changing out water pumps when the seal gets screwed up by junk in the system.
Wow! That's some nasty stuff! I'm just curious, what did that stuff feel like? It doesn't look "gritty" it just looks like rust dust. Did you use distilled water when you filled the system? Again, just curious. I may need to move that mod up on my "to do" list... My biggest problem is that I have big plans and no money.
It really doesn't have to be a IH pump, just a filter installed. I went thru a couple WP's on the mule before installing a filter and haven't had to replace one since.
I feels like rubbing compound, a little smooth but you can feel a fine grit in it. I always use distilled water. Big plans keep your mind active, your hands busy and your wallet empty, LOL. I'll probably go 7K more miles before getting back to AZ in Oct and will change it again. Now that I saw this I'll have to cut it open again, LOL!!
Gabe and whoever has a IH WP, when I turned the valve off and pulled the filter, coolant keep coming out at a trickle. Maybe there was some junk in the valve, IDK.
Any comments on my 'air scoop'?
I like the "Ram Air (Condidtioning)"! LOL!
I always assumed the intent of that flap was to force the air to go THROUGH the radiator and not to just flow out between the back of the bumper and the front of the "stack of cooling" that you have in there now. I guess as long as you're moving at sufficient speed, the airflow should be sufficient to keep the flow going through the radiator, but at lower speeds I would be worried that it would allow too much air to go out and around than through the radiator, trans cooler, intercooler, etc... I think closing off the sides might help. If you want another one of those rubber flaps to help close off the sides of the gap there, let me know. I found on in the loft the other day and was tempted to toss it, but for now it's just sitting up there collecting dust. You can have it for the price of shipping if you want it.
I did this 'Ram Air' mod on the mule a long time ago and never did have any temp issues. The only time it would run up a little in temps would be on a hard pull. You make a very interesting point about closing off the sides to help direct the flow. I'll take a look at that today. Really all that's different is the front of the rubber flap is lowered a couple of inches, the sides are the same for the most part. Maybe a little bit of extra rubber on the sides will help direct the flow. Thanks for the offer, I'll let you know.
OK - took the plunge today and ordered my waterpump. Hope to get it in before the end of June. Thanks for the nudge.
