Need wheels/tires
Old Jun 14, 2013 | 12:45 PM
Crazy66Dog's Avatar
Crazy66Dog
Need wheels/tires
Got my 49' 226 6 running pretty good but I have 30 year old bias ply tires that scare the bejeezes out of me.
I thought I had a cheap solution, my 2002 F 150 spare tire would look pretty good on it and I thought I could go junk yarding and get a set for $20 a piece or so.
Alas I just came in from trying to mount on the F1 and the bolt circle is too small, just barely.
Any ideas on how I can get a cheap set of wheel/tires.?
What years Ford truck wheels will fit?
Old Jun 14, 2013 | 07:24 PM
wallster's Avatar
wallster
You can measure your existing wheel and find out what size wheel you need to replace it with. You need to have three measurements to fit a wheel (technically four, you need the wheel diameter as well). 1. spacing of lug holes (
that explains how to measure this). 2. Width of the wheel (
that explains this). 3. Backspacing, (or offset... see the last video link).
If you know these specifications you will know which wheels fit and which ones wont. I'm betting you have a 15" diameter wheel, 5 lugs, 5.5 pattern, and about 3.5" backspacing or zero offset. If you do, most late model Ford wheels should fit (1960's, 70's, '80's and even '90's f150, econoline van, etc...) good luck.
Wally
1951 F1 - ol' red
Old Jun 14, 2013 | 11:04 PM
tinman52's Avatar
tinman52
Welder User
As Wally said above.... Stock F-1 bolt circle is 5 on 5 1/2". Wheels from any 1/2 ton Ford pickup or van up till about '98 will fit......should be easy to find.
Old Jun 14, 2013 | 11:27 PM
dmack91's Avatar
dmack91
Jeep CJ's and Dodge 1500 up through 2010 fit also, but check the backspacing on the newer ones.
Old Jun 15, 2013 | 06:30 AM
Crazy66Dog's Avatar
Crazy66Dog
Thanks guys I'll start searching.
MtnBikinPilot
Feb 5, 2016 03:39 PM
Don_Larson
Jun 8, 2012 02:05 PM
E150 4.9 1990
Apr 13, 2011 04:53 AM
f3f350
13
Mar 4, 2011 01:08 PM
kciv00
May 17, 2006 08:42 PM
