Found the problem!!!!!!!!!!!
Old Jun 9, 2003 | 09:57 PM
shep89's Avatar
shep89
Thumbs up Found the problem!!!!!!!!!!!
After changing timing gear, all new sensors, two new fuel pumps, filter, reg. Timing stuff. The problem was in the little fuel bowl between the lift pump in tank & the high pressure pump. Get this Ford Motor Co. said their is nothing goes wrong with those. Check Ign. Inside of fuel inlet is a check valve and o-ring. The o-ring came off and stuck the check valve closed. A $42.00 part. And I spent over $900.00 on parts. Well I guess it will be good for a while. I would like to thank all you guys for the help, the info was great, learned alot. Thanks Again.
