Cannot find web page :(
Old Jun 13, 2013 | 10:16 PM
Kurt G.'s Avatar
Kurt G.
The other day I was surfing web and found a site that had 292 oilpan gasket, rear main seal and oil pump gasket. I thought I bookmarked it but did not. Anyone know who sells the three as a package deal??? any help would be great, thanks.
Old Jun 14, 2013 | 06:47 AM
topmoo's Avatar
topmoo
These are the only two that I have bookmarked. Not sure if they have the exact set though.. 1958-60 Edsel Engine Gaskets - MAC's Antique Auto Parts or ford y block parts - BuyCheapr.com
Old Jun 14, 2013 | 08:54 AM
Kurt G.'s Avatar
Kurt G.
Thanks topmoo I'll check them out, I wish I could find the one I lost it said $29.99 for oilpan, rear main and oilpump gaskets. The guy said often oil pump was also a contributor to oil leakage.
Old Jun 14, 2013 | 05:39 PM
topmoo's Avatar
topmoo
I don't know much about Y blocks, I thought I might get one free so I bookmarked a bunch of pages but the offer fell through. Good luck with yours!
Old Jun 14, 2013 | 06:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Kurt G: Have you tried a local indie auto parts store or NAPA? Either should have the parts. Lockport NY (Mac's) is a loong way from WA
COAZ-6710-F .. Oil Pan Gasket / Obsolete
GREEN SALES CO. in Cincinnati OH has 18 = 800-543-4959.
B4A-6626-B .. Gasket-Pickup Tube to Oil Pump / Obsolete
GREEN SALES CO. has 88.
B6Q-6659-A .. Gasket-Oil Pump to Block / Obsolete
PARTS INTERNATIONAL in Farmers Branch TX has 10 = 888-727-0418.
GREEN SALES CO. has 196.
2) C9OZ-6701-A .. Rear Main Seal-Rope Type-Cut to fit / Obsolete
GREEN SALES CO. has 14.
PARTS INTERNATIONAL has 50.
DON SANDERSON FORD in Glendale AZ has 99 = 623-842-8643.
If I needed these parts, I whiz over to Engler Bros. Auto Parts in Santa Monica and get 'em there.
Old Jun 14, 2013 | 08:28 PM
Kurt G.'s Avatar
Kurt G.
Thanks NumberDummy I just thought if I could find the one webpage it would be nice. My Y is leaking oil from the pan/seal area and though his kit would be great but I cannot find it, so plan B "what you said". Hey I use to live in La Habra, in fact if you drove by LHHS you saw our 54 sitting on corner of Whittier BLVD and Monte Vista. Yellow at the time but that was in the early to mid 70's. Thanks for the info.
Old Jun 14, 2013 | 09:45 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Did you look in your History for your browser?
Old Jun 14, 2013 | 10:40 PM
Kurt G.'s Avatar
Kurt G.
ALBYQ to be honest, I hadn't thought of that. I will check thanks for the recommendation.
Old Jun 15, 2013 | 04:21 AM
NumberDummy
I'm a 'west sider' born (9/9/1944) and raised, moved from Santa Monica to Hacienda Heights 10/2001.
But, after WWII ended, dad was transferred from Heavy Cruiser USS Quincy (CA-71) to Bremerton, decommissioned ships thru 6/1947.
Since housing was in very short supply, dad, mom and I lived on a goat farm on Vashon Island.
Old Jun 15, 2013 | 05:54 AM
raytasch's Avatar
raytasch
Believe Nothing
Unless you know exactly where the leak is originating, don't overlook a leak coming from the top of the engine. There are a couple of bolt holes into the manifold that are unused. I've seen it more than once, on here once after a new rebuild, where someone leaves the bolt out of these holes. All is well till the engine is run hard. Check the top rear of the head, each side. Valve covers, valley pan are two more common areas for leaks. Just a FWIW.
Old Jun 15, 2013 | 10:06 AM
Kurt G.'s Avatar
Kurt G.
Thanks raytasch I will check those but I have a strong feeling it's seal/pan but I will look. Thanks kurt.
wcoleman
1978 - 1996 Big Bronco
23
Nov 30, 2005 06:20 AM
