Sponsored by: Auxito
Starting problem help needed
Old Jun 10, 2013 | 01:54 PM
myluckystars's Avatar
myluckystars
Ford F150 truck, when starting, the starter will turn over strongly for half a second then just abruptly makes a loud noise and stops. It won't ever fully crank. Is this just a bad starter?
Thanks for any help !! ~Staci
Old Jun 10, 2013 | 06:05 PM
Bluegrass 7's Avatar
Bluegrass 7
Likely is but do check out the flywheel ring gear for broken teeth or the motor is jambing up for some reason.
Be sure some belt drive item is not the cause as well.
Good luck.
Old Jun 12, 2013 | 10:22 AM
blueeyedfordguy's Avatar
blueeyedfordguy
What year is the truck? I would say it sure could be a starter issue. But if the battery is quite dead or old and weak it would cause a similar issue . I know with my 97 I can watch the battery voltage on the dash while I'm cranking. Other wise take a seperate person checking battery voltage with a digital multi meter / voltage meter. If while cranking your battery goes below 9.5 Volts your battery is low of charge or could have internal problems such as a bad cell. Bad positive or bad ground connections to the starter could also be the problem. I was shown at work to start at the battery and work your way to cables and starters. If the battery is at fault it is possible to get a new one, or put a pair of jumper cables/ good battery charger on it to be able to start it and drive to the auto parts store if you had to.
mb5518
1983 - 2012 Ranger & B-Series
Nov 14, 2014 10:11 AM
Indy443
Apr 10, 2014 11:19 AM
User 93024
2004 - 2008 F150
Nov 24, 2013 08:55 AM
Bobtailfan
Electrical Systems/Wiring
Jun 21, 2012 01:48 AM
nothercrash
Jan 10, 2011 09:39 PM
