So there I wassssss
Old Jun 9, 2013 | 10:36 AM
gdunn's Avatar
gdunn
So there I wassssss
I was towing my boat yesterday up to Pedro and the engine shut off when i rolled into a small town and then all my oil blew out off the intake manifold area
putting about a gallon on the ground. I lucked out, there was a AAA towing station across the street and the came over and pulled me into there lot.
Any way when I looked on to the manifold with a flashlight I found an 1-1/2"
"o" ring and a "c" clip. What is this off of?
Its a 1999 F250 SD 7.3
Any help would be GREAT!!!
Thank,s
Old Jun 9, 2013 | 11:03 AM
PennsyDutchman's Avatar
PennsyDutchman
More info
Originally Posted by gdunn
Any way when I looked on to the manifold with a flashlight I found an 1-1/2" "o" ring and a "c" clip. What is this off of?
Thank,s
I have to "assume" you've used the flashlight to look for any obvious disconnected hoses/lines? Have you checked to see IF there is any oil left in the engine? Are there any obvious signs of where the oil came from?
Really need more information before anyone can do some long distance "guessing" on what or where those parts are from.
Hope others can chime in here.
Old Jun 9, 2013 | 11:28 AM
gdunn's Avatar
gdunn
It's not the one off the side of the pedestal so im not sure where it came from.
Old Jun 9, 2013 | 12:16 PM
Kdr358's Avatar
Kdr358
Sounds like you blew a high pressure Oil line, there is one on each side. 1-1/2 is a little large, have you checked the turbo and the IC boots?
Old Jun 9, 2013 | 12:22 PM
gdunn's Avatar
gdunn
Ya it's not the high pressure lines. I got out a mirror and found its the high pressure oil pump. the c-clip and cover blew off. It was replaced a year ago.
I have to call my mechanic that did the replacement and see what the warranty is. If any. LOL
Old Jun 9, 2013 | 12:34 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
If no warranty consider the usual upgrade, a T500. Where are you located?
Old Jun 9, 2013 | 12:35 PM
gdunn's Avatar
gdunn
castro valley Calif
Old Jun 9, 2013 | 12:49 PM
aawlberninf350
It's a Van Gogh
Well hello Bay Area neighbor! Clay at RiffRaff is up in Oregon, and Joey at Terminator is on Modesto, so getting a T500 quickly should not be hard. Dang, towed the truck all the way back from Don Pedro?!
Old Jun 9, 2013 | 06:04 PM
DND58's Avatar
DND58
Agreed, more info needed by looking around for obvious. But it just may be parts from the EBPV.
Here's a link to Bob's site and a rebuild kit if that's it. There's other options also. Might try posting in the 7.3 section
99-03 Turbo Pedestal EBPV Rebuild Kit
Old Jun 9, 2013 | 07:04 PM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Powerstroke Diesel forum.
Old Jun 9, 2013 | 07:14 PM
Stewart_H's Avatar
Stewart_H
John, just FYI buddy, the OP already has the exact same thread he started here.
I'm gonna merge them together.
Stewart
Old Jun 9, 2013 | 07:15 PM
powerstroke72
Sounds good.
Old Jun 9, 2013 | 07:17 PM
Stewart_H's Avatar
Stewart_H
Threads merged.
Stewart
Old Jun 9, 2013 | 08:20 PM
MTDewX's Avatar
MTDewX
that 1 1/2 was stumping me as I have just done the HPOP and lines, fuel bowl and nothing in that area has that big of O-ring. but the EBP as I have rebuilt mine too. this would make a good possibillty. strange for it to come out though.
Old Jun 10, 2013 | 10:05 AM
gdunn's Avatar
gdunn
ya it is the h.p. pump.
i will be having it towed in later today. I talked to my mechanic and he is checking into the warranty. i will be looking at getting the T-500
my truck is stock except for the programmer , air intake and exhaust system.
will the T-500 be ok with stock injectors?
