85 ford f150
Old Jun 8, 2013 | 06:58 AM
monkey jason's Avatar
monkey jason
85 ford f150
i want to swap 351 w with my 3006, what distributor does the 85 351w have?
Old Jun 8, 2013 | 07:12 AM
Franklin2's Avatar
Franklin2
The 351w was introduced in the late 60's. So it can have a points distributor. Then around the mid 70's they introduced the duraspark system that was electronic, and they still had the 351w in production so it can have one of them also.
They converted the 351w to EFI in about 88 or 89(I think thats right) and it got the TFI type distributor till they quit making the 351w.
There are some odd ducks out there that were made with special ignition systems, usually bound for California.
But it doesn't really matter, all the different distributors will swap out. A 300 dist won't fit though if that's what you are asking.
Old Jun 8, 2013 | 07:17 AM
Franklin2's Avatar
Franklin2
I just saw the "85 351w" in your post. That would have the duraspark II dist.
Old Jun 9, 2013 | 08:22 AM
monkey jason
85 ford f150
Thanks, ive been having problems with my 300 6 so rather than put money in to it im thinking about putting a 351w in it.
Old Jun 9, 2013 | 09:08 AM
86fordtruck's Avatar
86fordtruck
Hey Jason,
Keep in mind, there are a lot of little things to consider with you engine swap. You'll need new frame perches for the engine mounts. The radiator will have to be swapped out, exhaust will have to be redone, etc. The 300-6 is a good motor, and the money you would have to spend to swap in a tired 351W could make that 300 run like new again. Just an idea. Whichever way you go, good luck with it.
Stangman70
Mar 19, 2019 12:38 AM
restoringmy46
Dec 26, 2010 06:13 PM
AlbraiNYa
WTB - Parts & other
Nov 4, 2010 01:57 PM
Dreamsickle
Mar 29, 2005 12:16 PM
fordtrks4fr
Oct 28, 2003 01:53 PM
