Transmission compatibility amongst engines
So I've found a couple of C6 transmissions on craigslist, one a recent rebuild that is close by. I have a 390 in my 74 (though it is not a truck 390 but a 67 Fairlane 390). Which engines would I need to look for (and years) that would have a compatible bell housing?
Thanks!
Thanks!
The transmission you need isn't too hard to find, its just a regular C6 transmission, nothing like what is posted below, that is Highboy specific. You just need to look for one with a FE bell housing.
Highboys have a specific transmission when your talking about the C6. You can't just use a regular 2wd transmission (well you can, I did but you need to mod the T-Case lever thingy), the C6's that were in the Highboys originally have a different tail shaft. that tail shaft have a hole in it for the T-Case lever. These are very very hard to find.
Here is a pic of the different bell housings.
One more question - i just called a guy about 30 miles away. He has a good running C6 behind a blown 390, in a 1975 F100 (I think it's a 75 - Mfr. date says July 1975), but for some reason, he's telling me there's a floor shifter. Would there be any issue buying a C6 that has the floor shifter? Is just the linkage different, so I could use mine?
the previous owner had done a hack job and converted to floor shift. It's a Ranger XLT F100, 2WD, 390. I guess it could be a 76, but maybe 75...
