Firestone airbags not leveling F350
And I see by your avatar you might be a Marine. Thanks for your service.
Miles at first I thought your friend had a 5er trailer, now that I see its a bumper pull with the info you have provided it sounds like a WD hitch setup properly would make a big improvement, it would at least get the frontend back down and allow for safer handling. As opposed to the front going sky high as you said.
My 2013 dually has about 2000lbs. of tools and stuff and I have to have 40psi of air in the bags just to keep it level. In my 2008 f350 SRW I really did not need bags to keep it level, I just put 10psi so I didn't hurt the bags. That 4" block makes a huge difference. Putting a 2" block on a dually is a mistake on Ford's part in my opinion.
Here is mine. About 2800lbs weight in the bed, including tongue weight, and 50psi if air in the bags. This much sag is embarrassing.
photo2021_zps4f76e1fe.jpg Photo by dualwheels66 | Photobucket
X2 on air springs. If you have proper pressure for the weight it wont sag no matter how mushed the springs have become.
I think I'd like to get some air bags on my dually. Had them on my 250 and did a great job. My truck gets a little too much nose up with a 3800lb dump trailer with maybe 1000lbs in it in tow. 8 yards of dyed black mulch and I was dragging the safety chains. Max that would be 8000lbs so ~12k total, but more likely 6400lbs for a 10,400 total. I wish the guys at the local yard would learn how to load trailers though. He put almost all 8 yards from the forward axle to the front of the dump box. Serious tongue weight!! Anyone ever use weight distribution with a trailer like a dump trailer where the load varies quite a bit? I've upgraded my hitch to a 18,000lb, 2000lb weight carrying, 2500lb weight distribution.
But I agree, too much sag for my dually with lighter loads. Guess I'll just need to upgrade to that new F-550 dump......and get then get used to sleeping on that basement couch!!
I'm not sure if my upgraded hitch (Reese Titan) follows the rules but that hitch compared to the stock 2 1/2" is a, well there is no comparison. It's massive and has extra attachment points along the frame. The ball mount is also one massive piece. I'm sure it's not the "correct" way to do things but gives me a little piece of mind when the dump is loaded. If I would have thought this through I may have opted for the gooseneck.
#28
Putting airbags in may not be the answer. The bags may act like a fulcrom when used with a bumper hitch trailer. Even more so on a regular cab truck. Heavy tongue weight with a short truck with filled bags could jack up the front end. I bet if he had a cc/lb like his 04 it would make a difference. Airbags work great for us with 5ers or haul things in the bed.
#29
