Change Grille
Old Jun 9, 2003 | 01:58 PM
Dan76'F100's Avatar
Dan76'F100
Question Change Grille
What would I need to get/do to convert to a 78' - 79' grille with square headlights... Would I need the whole front end or core support to change or can I use my old one somehow???
Old Jun 9, 2003 | 02:58 PM
Mil1ion's Avatar
Mil1ion
Change Grille
To swap to Rectangular headlights
They aren't square.
You will need the headlight buckets and hardware, the grill surround, & Grill
Old Jun 9, 2003 | 03:05 PM
73Custom's Avatar
73Custom
Change Grille
I have installed a '79 grill on my '73, it's easy - a bolt on swap using your '76 radiator support with a couple new holes.
Get these parts from the donor truck.
grill surround
grill
headlight mounts
headlight trim
blinkers (get sockets too)
corner brackets (bolt onto the top of the rad support and hold the top outer corners of the grill)
Remove old grill and headlight mounts. Install corner brackets and bolt top of new headlight mounts into bracket and drill new holes for the bottom two holes. Then everything else will bolt right up. Cut and splice the new blinker socket in place of the old one. Easy.
Marty
Old Jun 10, 2003 | 01:05 AM
Matts72's Avatar
Matts72
Change Grille
Yeah its a pretty easy swap except I went the other way, a '75 grill(e) on my '79.
