Topping Off
Old Jun 7, 2013 | 10:58 AM
SurryGent's Avatar
SurryGent
Topping Off
Fueling my pervious PS's 1997 & 2008 Icould fuel to the top of the filler, without too much of a problem ordelay. That way I could get an accurate MPG calculation. Mypurchased new, 8000 mile, F-350 PS is almost impossible to fill unless you wantto take a half hour to do so. What it does is fill to the top then drainsback into the tank. Yesterday was the first time I topped it off and like Isaid it took almost a half hour. With the small tank that extra fuel doesmake a difference and does give an accurate MPG figure. Does anyone elsehave this problem?<o></o>
Old Jun 7, 2013 | 11:28 AM
djousma's Avatar
djousma
its not as big a deal as it was in the older trucks. For me, in my 2005, I could get a few more gallons in. I know a lot of guys did the "harpoon" mod on those years. In my 2011, its only a gallon at most, usually less. I find myself topping off occasionally out of habit, but it really isnt necessary anymore.
I've learned to just trust the computer as the gallons used is always within a .10 or so of pumping it in.
Old Jun 7, 2013 | 12:37 PM
CascadeF250's Avatar
CascadeF250
I never top off the tank when fueling. The computer is always very close for me also. I don't like to take a chance on fuel spilling on the side of my truck.
Old Jun 7, 2013 | 01:06 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
I fill to the point where the auto-shutoff happens each time I fill-up. I reason the calculations are very accurate.
Old Jun 7, 2013 | 02:16 PM
Grout-Scout's Avatar
Grout-Scout
Hmmm wierd, my read out is always over by 1mpg and when I top it off it is almost where the clicker stops at. Mine won't take but maybe 1/10 of a gallon after the click, it's right at the top of the neck.
Old Jun 7, 2013 | 02:24 PM
jdadamsjr's Avatar
jdadamsjr
Since I'm driving an 8800 lb square box that sometimes runs around @ 23,000+ lbs towing,
I'm not overly concerned with mpg...
besides that, the fuel gauge, DTE, the computer, but mostly my wife, does a good job of warning me when I'm about to run out of fuel
Old Jun 7, 2013 | 04:15 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Howdy my Friend........
I made a trip to Tucson AZ and back with the F-350 and the 33ft 5th wheel (about 13k lbs). 2800 mile round trip. Many 6% grades.......75 mph cruse speed coming home......10.4 Miles per Gallon. Going there...65 mph cruse speed....11.5+ miles per gallon.
The truck does well.........
Old Jun 7, 2013 | 11:20 PM
jdadamsjr's Avatar
jdadamsjr
It IS a towing machine - but 75 with THAT weight ?!?!
hope you don't have ST tires limited to 65 mph on that 5er then ?
(but when it's not summer and really hot, I will bump the rv's tire pressure up and run 'quickly', but not usually )
Old Jun 8, 2013 | 11:06 AM
rob17's Avatar
rob17
I was thinking the same thing.
Rob
Old Jun 14, 2013 | 04:34 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
It was cool weather............
I figured that since the trailer was behind the Truck......it must have been going slower.........maybe about 65mph................
Seriously.....you do have a valid point!
Old Jun 14, 2013 | 04:37 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Rob
The weight was just not a problem........the Truck towed (at 75) uphill (6% grade ) without any heat problems nor lack of power.
Trailer tires speed rating.....??.........I must admit, I do not know what my tires are rated for.
Old Jun 14, 2013 | 05:51 PM
69cj's Avatar
69cj
If you ever spin a tread at that speed you can kiss that side of the trailer bye-bye if your lucky.
Old Jun 17, 2013 | 11:20 AM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
IF.......the tread of a tire was to seperate at 65 mph...vs...75 mph, the difference would be very very little. Brake out your slide rule and do the math of the froce excerted by the mass of the tire tread on the side of a trailer at 75 mph vs 65 mph.........The damage would be simular.
But...ya know, this is not the subject of this thread anyway. And which university did you get your Ph.D in physics??
Old Jun 17, 2013 | 10:51 PM
shadowSVT's Avatar
shadowSVT
Roy, most trailer tires are rated for the weight expressed at pressure and 55 MPH.
decreasing air pressure or running faster causes the tires to heat up and fail.
Best thing you can do is upgrade to ribbed style tires and keep the needle at 65 or less.
Old Jun 18, 2013 | 10:53 AM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
I went to "The Tire and Rim Association" ...........(with the help of Good Sam's Club)
The Tire and Rim Association, Inc. (TRA) is the standardizing body for the tire, rim, valve and allied parts industry for the United States. TRA was founded in 1903 and its primary purpose is to establish and promulgate interchangeability standards for tires, rims, valves and allied parts.
I have seen so many experts on FTE telling people what they need to know about weight limits, towing limits, tire limits and safety. The BIG problem (for me) is that the information in not consistant, is not backed by verifiable sciencetific research......So what is one to believe??
Common Sense does play a part......but only if it is based upon sciencetific research.
RV Trailer tires are typical rated for 65 mph...At the Full load with the recommened air pressure. The standards go on to say: At the fully rated load the tires are rated for 75 mph with a 10psi air pressure increase.......Also, the tires are rated for 75-85 with full air pressure and a 10% reduction in load.
So, the blank statement that the world is going to end if you pull a trailer faster than 65mph is just plain untrue.
The axles on my 5th wheel (and therefore tires) are not loaded to the max load capability of the axles and tires. I keep the pressure at max recommened. I monitor the temp of all tires. I drive for the traffic and road and weather conditions....
I might drive at 65 on a 80mph posted road. Traffic, weather (to include temperature) road surface material and condition. I might drive at 70mph. I do feel, for me, that 75 mph is plenty fast enough no matter how great all the factors are. I do choose to drive at 65 most of the time for the sake of fuel cost. There are some roads that are posted at 70mph here in Montana that I am comphy with 60 mph. I do keep in mind that, too slow can cause or contribute to some nasty accidents and is illegal in some states.
Be safe....be reasonable.......don't hurt people.......How you do this is up to you.
