my computer is acting funny every time I try to search older post? so, Im having a no start issue, cranks awesome, 4 or 5 times for 10 seconds, until the battery's start to drain. I stopped by the auto parts place and asked them to check the alternator while running. it was putting out 87 amps at idle. is this good amperage, or should it be higher? then he checked the batteries, engine off, 13.7v of course I did just get done driving for thirty minutes. I don't no the year of the batteries? I have only had the truck for 14 months and they are spotless and new looking. but could it be battery's? there made by centennial?
Im just wondering, it all started yesterday when the weather hit above 80 at work, so of course, after a long 10 hours, to walk out to the rig and Shniggle's! then first thing this mournin, I hooked the X up to it for 5 minutes and vroom!!! then today same thing? I bought an alternator, but shoot, I want save every penny I can so I thought id ask your opinions.
Thanks guys!
do you have any gauges to read live data? I would check ficm vlts,check batteries separete 13.5 is not bad single you could have a cell going out, also the FICM connections some times the pins get bent when Installing or not snaped in all the way,are the batts posts clean.on the no start try unplugging the ICP connection
Check the batteries with a hydrometer cell by cell, if you have one bad cell replace both batteries, I just did, your FICM will thank you........... also check your alternator output at about 2000 FPM, should be 13.5 to 13.7 approx
X3 on having the batteries load tested and they must be done separately ( completely disconnected from one another ) If the alternator was at hot idle when tested then the 87 AMPs isn't bad, but if one of the batteries has a dead cell the alternator wont last long putting out continuous maximum amperage.
Just as an aside. The experts can chime in here on this, but I think if you disconnect your batteries you'll have to follow the transmission re-learning procedure. Seems to be pretty easy and straight forward process.
Hmmm I just noticed that the batteries are both 650 CCA, everywhere I checked on the web and put in my vehicle, it only pops up with 750 cca and 850 cca batteries. Do any of you think that could be the issue? under powered batteries finally taken a dump maybe?
probally bad batteries or battery what year is your truck and do they look like originals, also where do you live ? get the highest cca you can find, easier on the total system
up in Washington state. I don't know much about these 6.0's but dang I just don't know? acouple guys said glow plugs, but its been in the 80's up here?
Actually if you've had the truck with a stock alt and 650 cca batts for 14 months: no I don't think that's your problem (anymore). Now I think you have a bad FICM and hopefully it stops there. Hard cold starts w/o other information is the first clue and then it's hard warm starts as the FICM dies a slow death.
You need to get some live data (for all times on a 6.0, but particularly now). Do you have a smart phone? Some of the best monitoring stuff out there is Dash Boss for and iPhone/pad or Torque Pro for a Droid phone/pad. Pretty much nothing else in the price range of those comes even close...
A lot of guys here use ScanGauge II -- good stuff, very time consuming to set up and it's a limited text only display when you get going; BUT: you can get one tomorrow and there are a TON of experts here to help you with it!
my buddy came over with his 6.0, changed batteries and no... she cranks like a dream but no run. we swapped FICM relays, nothing, checked the FICM on the valve cover, everything checks out. checked the glow plug control and its at .7 ohms I believe is what he said. hmmmm. she cranks, she gets fuel, the glow plug C.M. im trying tomorrow, ugh lots of fun carpooling to work....
So you swapped batts with your bud's truck or did you try jumping it? If it ran just fine, and then would start only with a jump, and now not start at all...
Hmmm, there have been bad FICMs that test out ok, but it sounds like we have that or another gremlin that's popped up. Does your buddy have any way to monitor the truck in real time?
Would really like to know for sure what your FICM voltages read while cranking, and then there's several other things Benny will help you check. But need some data at this point...
