Sponsored by: Auxito
Whine on Deceleration
Old Jun 6, 2013 | 09:59 PM
trk pny's Avatar
trk pny
I have a 2000 5.4 4x2 with about 118k. the pinion seal was leaking. I replaced the seal and added proper amount of 75/140 diff fluid as listed on the tag. I marked the pinion nut, flange and housing, so I could count the number of turns it took to remove nut. I put back the same but now I have a whine at low speed on deceleration. under normal throttle and at higher speeds it sounds just fine. Its just on deceleration and at 5mph or less. The sound was not there before I did the new seal. Any ideas? thanks.
Old Jun 7, 2013 | 04:31 PM
Bluegrass 7's Avatar
Bluegrass 7
You upset the bearing pre-load pressure and depth.
Try tightening the nut a fraction of a turn and see what you end up with.
Otherwise you would need to start over again with a new 'crush' sleeve' and tighten to spec.
Look up how this all works so you see what it's about.
Good luck.
Old Jun 11, 2013 | 11:17 AM
brokenleg's Avatar
brokenleg
Good luck.
Yep....agree with above.
Thisguy65
19
Jun 8, 2017 11:44 AM
Excurvelle
Mar 28, 2015 05:47 PM
gotatrucksomeonehere
May 26, 2013 02:13 PM
cajunsuperduty
Aug 19, 2011 08:50 AM
hfdbuck09
Sep 20, 2010 07:33 AM
