IDI turbo bark?
Old Jun 6, 2013 | 04:21 PM
Eallend7's Avatar
Eallend7
IDI turbo bark?
has anyone ever had an idi turbo bark?
went ridin to the store with my buddy in his duramax at work and his turbo barked every time he would kick it and let off.
said it was from mattin the gas and lettin off real quick and not giving the turbo time to slow down before letting off.
Are our turbos just too small for that? i know the dmax turbos are huge in comparison, just kinda wondering what makes that happen on a newer truck that wouldn't happen on an old one
Old Jun 6, 2013 | 05:09 PM
turtlemann14's Avatar
turtlemann14
you don't want that to happen. it can snap the shaft in the trubo.
this is why gas engines use blow off valves.
all turbo bark is is the compressor stalling, this results in a high torque load on the shaft running from the compressor to the turbine.
it not happening on an idi is a combination of a small(no inter cooler and all of the piping), low pressure(generally 14psi) reservoir of pressurized air and a turbo that has low momentum.
run6.0run
Jan 24, 2016 06:39 PM
trevorrules
Jun 21, 2015 04:16 PM
High Binder
6.7L Power Stroke Diesel
Nov 8, 2010 07:01 PM
bad12jr
Dec 11, 2009 03:39 PM
smdenlinger
May 23, 2008 03:09 PM
