What's this?
Old Jun 6, 2013 | 12:46 PM
super fly's Avatar
super fly
What's this?
Could some please tell me what this bushing is called so I can try and get another one. It looks like the bottom of this one is gone.
Old Jun 6, 2013 | 12:59 PM
Greasemonkey93's Avatar
Greasemonkey93
if im not mistaken its called a body mount
Old Jun 6, 2013 | 01:28 PM
tjc transport's Avatar
tjc transport
i ain't rite
under the radiator, or under the cab?
under the radiator is a radiator support mount, under the cab in a cab mount.
and yes, the lower bushing is missing.
rite now that is not doing anything except holding what is above it off the ground.
Old Jun 6, 2013 | 01:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
As you can see.
Old Jun 6, 2013 | 02:10 PM
super fly's Avatar
super fly
I've search rock auto and advance auto parts online. The only thing I have been able to find so far is an Energy Suspension Body Cab Mount Set on advance auto parts. Am I going to have to buy a whole set of mounts? I'd like to just replace the one for now. Thanks!
Old Jun 6, 2013 | 02:25 PM
BigBlockF350's Avatar
BigBlockF350
They're body mount bushings. If one is going, the others could probably use replacement too. Summit sells a set for $55. I put these on my truck recently.
http://www.summitracing.com/parts/pt...rd/model/f-150
Old Jun 6, 2013 | 02:27 PM
NumberDummy
Which cab mount do you need the lower absorber (aka bushing aka cushion) for? Front or rear?
Front right/left lower: E2AZ-5400155-A
MALOUF FORD in North Brunswick NJ has 2 = 732-951-0500.
POECS PARTS in Erie PA has 3 = 888-864-9305.
COLONIAL FORD TRUCK in Chesapeake VA has 12 = 757-485-8285.
Rear right/left lower: EOTZ-1000155-C
POECS PARTS has 10.
PARTS INTERNATIONAL in Farmers Branch TX has 20 = 888-727-0418.
GREEN SALES CO. in Cincinnati OH has 79 = 800-543-4959.
Old Jun 6, 2013 | 02:33 PM
super fly's Avatar
super fly
How rusted on there are they? Am I going to end up having to cut them off and get new hardware lol? How long did it take you to replace all them? If I could just buy the one and replace it for now that would be ideal. I only use the truck once in awhile to go to Home Depot/lowes, transport dirt bike etc. It's not my daily driver. Plus it's a 700$ truck; rusted, dented, paint coming off lol. Besides a tune up when I got it Ive just been replacing things as needed.
Old Jun 6, 2013 | 02:36 PM
Encho's Avatar
Encho
The Southernmost Mod
If that one is like that the remaining ones probably are in the same shape, you won't be wasting resources buying the set anyway, but if you want them by the unit you'll probably find them, keep looking.
Old Jun 6, 2013 | 02:37 PM
super fly's Avatar
super fly
The front, just in front of the right front tire. Thanks!
Old Jun 6, 2013 | 02:41 PM
BigBlockF350
I don't know how bad they are on your truck... On mine, all of the bolts came out pretty easily, I've got next to no rust underneath my truck though.
If they're badly rusted and worn, I've seen body mounts just fall off and leave the truck sitting a little sideways. If they're bad, it could be a safety issue.
Possibly...
I was installing a 3" body lift at the same time, so it's hard for me to say exactly. But probably about 2-2.5 hours for the 6 cab body mounts.
I'm not sure where you could buy only one... Like I said before though, if you have an issue with one then the others may not be too far behind. You might be best off just to buy a whole set even if you only replace them one at a time.
Old Jun 6, 2013 | 02:45 PM
NumberDummy
Look at post 7 again, I edited in the sources. Ford dealer in NJ has 2 of the fronts.
Post 7, you can buy one or all of the puppies.
Old Jun 6, 2013 | 03:03 PM
super fly's Avatar
super fly
Thanks for the help
Old Jun 6, 2013 | 04:01 PM
tjc transport
i ain't rite
never mind, Bill has it covered.
Old Jun 6, 2013 | 11:31 PM
joey2fords's Avatar
joey2fords
the sheet metal that it is going into looks pretty cancerous ...
