another EGT sensor.
Old Jun 6, 2013 | 04:01 AM
mebe2k's Avatar
mebe2k
another EGT sensor.
here we go again..EGT sensor #2..last time it was #4. on 3/25/2012...are 1 or 3 going to fail next year?
Old Jun 6, 2013 | 05:04 AM
senix's Avatar
senix
Wonder if you can check on the sensor's. If they are the same as what is used on the 6.4 or...will they interchange?
While the 6.4's will suffer the same they have not failed like this.
Old Jun 6, 2013 | 05:29 AM
mebe2k's Avatar
mebe2k
i'm thinking of checking the price on these sensors and maybe keeping a spare "just in case" under the rear seat..don't want to be stuck on the side of the road somewhere if this happens again..thankfully it did this while in my driveway..last time it happened, it was at a red light..truck shut down, refused to restart.
I wonder, if you unplug these sensors(if you scan for the codes and unplug the right/failed sensor) will the truck atleast go into "limp mode" so you can get it to run again?
Old Jun 6, 2013 | 05:32 AM
senix's Avatar
senix
I agree, carry a spare. someone on here said they were like $37 bucks.
Old Jun 6, 2013 | 06:37 AM
golfmedik's Avatar
golfmedik
These things are really beginning to p!$$ people off! No other manufacturer has their trucks shut completely down by EGT sensors. This shutting down is as much of a safety concern as WHY it shuts down in the first place! Funny how airplanes use sensors like this all the time and they have a near ZERO failure rate, but these are failing right and left. I know the aircraft ones are a lot more expensive, but someone somewhere had got to have a sensor that will not fail as often. Coming down a 6-7% grade with 15,000 pounds behind me is one of the last places I would want a failure. But there is no way to know when! So it's Russian Roulette......
Even if you carry a spare, you then have to have some sort of monitor, scanner to figure out which one it is.....this is getting ridiculous. I can see numerous complaints forth coming. I know my work place has filed one.
Old Jun 6, 2013 | 08:11 AM
darren32's Avatar
darren32
Check here for part number, yes $37.00. All 4 are the same:
https://www.ford-trucks.com/forums/1...l#post13077267
Check here for how to figure out which one is bad:
https://www.ford-trucks.com/forums/1...l#post13080181
EDIT
I meant to post kper`s DTC list todetermine which sensor is bad:
https://www.ford-trucks.com/forums/1...l#post13078443
Old Jun 6, 2013 | 08:22 AM
darren32's Avatar
darren32
I have checked with Exhaust Gas Technologies and they do not make a replacement (better) sensor (yet??). I have used their stuff for 20 years and never had a single one fail. Not sure where else to check but surely someone will come up with a replacement for these $5.00 pieces of junk!
Old Jun 6, 2013 | 09:56 AM
jimmystoys's Avatar
jimmystoys
Its funny you guys bring this up. Had all the deletes done to my truck and installed a Spartan tuner, so we robbed the sensors off the Ford exhaust that I removed, I think theres three of them, out of the two, (I broke one!) one worked and the other one failed not soon after. Here I am now about ten months later and I dont think that sensor is working very well or accurately, so we ordered one! And I think you guys are right, theres only the one brand. Wanted to purchase a better one but the one is all they have.......for now!? My truck didnt shut down or anything, the gauge just quit working.
Old Jun 6, 2013 | 10:58 AM
ngng's Avatar
ngng
Good to know, gonna order some now!
Old Jun 6, 2013 | 01:58 PM
mebe2k's Avatar
mebe2k
you'd think that they would've made the ECM smart enough, to check it's "other" EGT sensors and realize that the EGT's are not super high, and maybe just go into limp mode...the trucks i drive at work (Sterlings, Freightliners, and even the old Macks) just have a warning light that comes on when the EGT's are super high..the trucks DON'T shut down! And sensor failures are rare..I wonder if a different brand of sensor can be modified to fit our trucks?
Old Jun 6, 2013 | 06:48 PM
arkie3's Avatar
arkie3
tsb12-07-01
Old Jun 7, 2013 | 07:49 AM
darren32's Avatar
darren32
I would think for sure. As far as I know, they are just a type "k"... They read properly on my meter type K input and they read properly on my digitron. If I had any on my truck I would find the closest EGT has and splice into the factory connector. NOT SAYING THIS WILL WORK FOR SURE, I have nothing in my exhaust so I can't even try it.
Exhaust Gas Technologies Inc. - Motorsports Catalog=
100% Made In the USA!
Our Probes Feature:
  • Type “K” Calibration Special Limits, Traceable to N.I.S.T.
  • Inconel Outer sheath good to 2200 + F
  • Kapton Insulated Stainless Steel Overbraided Wire
  • Wire Length up to 72 inches w/ striped leads
  • Exposed Tip Junction Hyper Response can see a single misfire @ 8000 RPM
  • Response time 300 milli-seconds All Day Long!
  • This Probe is compatible with...Race Gasoline, Alcohol, Methanol, or Nitrous Oxide in naturally aspirated, Turbo charged, Blown/Supercharged Engines and Fixed & Portable Dynometer’s.
Exhaust Gas Technologies, EGT sensors are the #1 EGT sensors used in professional Motor sports world wide.
We currently supply the top teams in NASCAR, INDY,NHRA, IHRA, BONNEVILLE, and IMSA AND MORE.
We're the people that started EGT measurements in auto racing years ago. Everyone is still chasing us with many “Look-a-Like” products and pirated concepts.
No one has come close to our Performance, Longevity, Accuracy and Reliability.
Just ask the pros,
“The REAL PRO’S”! Custom Probes are a Daily Occurrence in our manufacturing plant! If you need something special! Give us a call 800-557-5152
Old Jun 7, 2013 | 02:39 PM
darren32's Avatar
darren32
Well guys....
I talked to Exhaust Gas Technlogies again and asked them if they would take a look a making a replacement sensor. I told them I would send them one.
Our man Rick there said....
"Sure we'll take a look at it. We need to cut it apart. Hopefully we can find a solution to these failures."
Soooo I will send them one next week and let you know what they say.
Old Jun 7, 2013 | 05:17 PM
golfmedik's Avatar
golfmedik
Originally Posted by darren32
Well guys....
That would be an awesome idea. Does anyone know if the 6.4s and 6.7s use the same sensors? I can't think of why they would be any different.
Old Jun 7, 2013 | 06:36 PM
Fontana's Avatar
Fontana
All vehicle manufacturers incorporate designed obsolescence. They can build a reliable vehicle. They don't want to. They want you coming back every 3-5 years for a new vehicle. The only way to get out of this cycle is to be a mechanic or buy a classic and instal quality parts. Learn how to pamper your own baby.
