trailer battery charge -- updated
Old Jun 7, 2013 | 07:57 PM
IDMooseMan's Avatar
IDMooseMan
Does this help?
I have it as a PDF file. I can try to PM it to you if you think it will help. My truck has the 7-way connector. I have the Camper Package and the Off-Road Package on my truck.
Old Jun 7, 2013 | 08:17 PM
427 fordman's Avatar
427 fordman
Ya, that helps me some. Thanks Craig. I'll take any information I can get if you want to pm or email me what you have.
Old Jun 7, 2013 | 08:39 PM
IDMooseMan's Avatar
IDMooseMan
The PDF file is the same as I put in the post. I have the 7-way connector listed at the top of that document. It, and the plug, looks exactly like the picture. If it isn't on your truck (under the rear bumper on the left side) let me know. I'll try to get some pictures for you.
Old Jun 7, 2013 | 10:57 PM
ReBilld's Avatar
ReBilld
Originally Posted by 427 fordman
Thanks for the picture and words of advice Bill! I'm not sure how soon I'll get to look at it, but now I have some sort of a plan anyway. BTW, you were one I couldn't rep..
edit: One thing, what exactly am I looking for if I want to find a factory harness? Maybe a stupid question, but I don't know.
If your truck has the two round plugs like in the pic, the factory 7 pin plug has a short harness (about a foot or so long) coming out of it with the two round plugs on it.
Old Jun 8, 2013 | 07:11 AM
427 fordman
Is this wiring harness not available new anymore? I'm pretty sure I remember someone saying that before..
Thanks again guys.
Old Jun 8, 2013 | 08:40 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Thanks again guys.
screw oem.only those who are restoring show trucks need to suffer with outdated stuff.
if your seeing the wiring back there but lack the plugs,check it out:
Hopkins 40985 Universal Multi-Tow Harness Connector : Amazon.com : Automotive Hopkins 40985 Universal Multi-Tow Harness Connector : Amazon.com : Automotive
Hopkins 40975 7-Way Round / 4-Way Flat Socket and Bracket : Amazon.com : Automotive Hopkins 40975 7-Way Round / 4-Way Flat Socket and Bracket : Amazon.com : Automotive
wire that in to the tow package harness you see under the rear bumper and your all updated and don't need the adapters for trailers that use the round or the 4.if you have any older trailers with the older 6 way plugs,don't even mess with adapters for those either.just update them to the newer plugs too.
it's just a few bucks,but makes it all so nice.i went through and did this to my truck and trailers and it was worth every penny and the time.
went right through my dump trailer completely with new wiring for everything once i added the brakes,and updated it's connector.i have use of everything on that one.tail,brake,blinkers,backup,battery charger.
it's nice to just plug in anything like a new truck without those frigging adapters on stuff.
Old Jun 8, 2013 | 12:26 PM
427 fordman
Thanks for the info F250, but I got it. I feel quite stupid again, I had all the wiring there. The first owner of the truck took the 7 way plug and converted it to the 6 way ones I have now. He just plugged the female end in and took 6 wires and ran them to the 2 hookups I have now. One in the box, one in the bumper. I mounted the plug onto the hitch underneath. Now with it connected like shown in the picture, I'm running power to the two 6 way plugs. Once I put a new 7 connector on the big trailer I can unplug the connector underneath and hook up that trailer. I need the other plugs for work trailers, so I can just unhook and lay that out of the way when not needed.
Turned out to be an easy fix, but I still gotta thank you guys for all the information.
Old Jun 8, 2013 | 02:08 PM
nomad221's Avatar
nomad221
Awesome Darin!! Nice to have easy fixes every once in awhile.
Old Jun 8, 2013 | 02:58 PM
427 fordman
That's for sure Greg! That doesn't happen very often, I was quite happy. All I had to do was pull the connector down from where it was tied up, took it off and cleaned the contacts, straightened and painted the bracket, and bolted it on.
Old Jun 8, 2013 | 08:59 PM
oldbird1965's Avatar
oldbird1965
Another electrical hurdle leaped over by Darin, YEAH. LOL
I should talk, mine was lighting up my dually fender running lights and lighting the camper lights when the pickup lights were off. I couldn't figure it out, asked my nephew and he switched a couple wires around and everything worked right. Duh!!
Old Jun 8, 2013 | 10:20 PM
ReBilld's Avatar
ReBilld
That worked out pretty good for you Darin! Glad you had it all there!
Old Jun 9, 2013 | 01:04 AM
IDMooseMan's Avatar
IDMooseMan
Easy fixes are the best! Glad it worked out for you.
Old Jun 9, 2013 | 06:18 AM
  #28
427 fordman
Thanks again guys. Glenn, one of these days if I keep messing with electrical crap I'm going to get better at it!
Old Jun 9, 2013 | 09:10 AM
  #29
oldbird1965
Hopefully me too,
Old Jun 9, 2013 | 10:11 AM
  #30
Ken_C's Avatar
Ken_C
this shows the charge wire in the trailer plug and what color it is
Skral
Jun 1, 2019 03:47 PM
surveyguy
All Things Towing
Apr 20, 2009 09:16 PM
mjolly5150
All Things Towing
Sep 7, 2006 02:53 PM
Mark VII
1997 - 2003 F150
Oct 16, 2004 03:23 PM
cocot
Electrical Systems/Wiring
15
Sep 28, 2004 12:44 PM
