Sponsored by: Real Truck
new noise
Old Jun 4, 2013 | 07:21 PM
jbrianas's Avatar
jbrianas
new noise
2012 truck, started making a noise today,
I cannot tell what it is, but seems to be coming from the passenger front suspension, its a crunching/light clunking sound, happens when going over bumps, when the truck pitches one way or the other turning, and coming to a stop
truck has 6k miles, I did a quick visual inspection this afternoon, didn't notice much, but the sway bar endlink looked a bit odd though, not sure if normal, its gota little bend too it and seems to just contact the vac line mounted behind it, seemed unsuaul
maybe its its just one of the crappy rancho branded shocks is junk?
any ideas whatelse to check?
thanks,
Old Jun 5, 2013 | 06:13 AM
redford's Avatar
redford
FTE Leadership Emeritus
Did you recently do any "Dukes of Hazard" style flying with your truck?
Old Jun 5, 2013 | 07:36 AM
snelldawg's Avatar
snelldawg
Try turning off the stability/skid control (button is located in the center of dash) and going over the same stretch of road.
My truck does the same thing....seems to be overly sensitive to bumpy on ramps or sharp turns in to parking lots.
senix's Avatar
senix
Check your cab bolts and radius arms. Maybe a loose shock.
Old Jun 5, 2013 | 04:54 PM
jbrianas's Avatar
jbrianas
lol, no dukes o hazard, noticed once i disconnect trailer and drive just truck it rarely will do it if at all, but with trailer on it does it constantly
i will check your guys suggestions though - thanks
Old Jun 5, 2013 | 04:57 PM
senix's Avatar
senix
There is a new TSB just release about this very issue. I forgot the tsb # and have not found it anywhere.
On the ford site it does not go in-depth.
Will keep hunting.
Old Jun 5, 2013 | 05:11 PM
jbrianas's Avatar
jbrianas
ok nice, be sure to post back if you see or hear any info on the tsb
CopperExpo
Jul 24, 2017 09:27 AM
THEDON117
Feb 22, 2015 09:58 PM
dvskate
Nov 24, 2009 10:10 PM
Parr8hed
Jan 28, 2006 08:04 PM
Mr Personality
Jan 22, 2004 06:27 PM
