Ficm problem....
Old Jun 3, 2013 | 03:10 PM
Fordman_95's Avatar
Fordman_95
Ficm problem....
I will be driving down the road and after 20 mins of driving my ficm voltage will drop to 44.5 volts or so then climb back to normal and it only seems to happen going down the hwy. It is with in spec like when the key on and on start up. its an 05 with head studs and egr delete done to it.
Old Jun 3, 2013 | 03:46 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
FICM.com Replace it.
Old Jun 3, 2013 | 03:48 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Good job! You caught it before it left you stranded somewhere. Another fine example of why you should have a insert your OBDII monitor name here In your truck .
Old Jun 3, 2013 | 03:58 PM
vectrex's Avatar
vectrex
So what exactly is the threshold for criticality on these things?
For example, my FICM voltage oscillate from 45.5(rare occasion of 45) to 48.5 while driving. This is withing operating range, but would it be considered a warning sign? It hasn't changed since I've owned the truck, and it's one of the four Xgauges I keep on religiously.
Old Jun 3, 2013 | 04:00 PM
Rusty Axlerod
<45v at any time.
Old Jun 3, 2013 | 04:04 PM
Frankenbiker's Avatar
Frankenbiker
Originally Posted by Rusty Axlerod
<45v at any time.
Um, that's backwards....
should be >45V....
-blaine
Old Jun 3, 2013 | 04:06 PM
Rusty Axlerod
I read yours as "greater than fourth five volts" no?
Old Jun 3, 2013 | 04:10 PM
vectrex's Avatar
vectrex
Is that including KOEO after cold soak? I've seen my start off at 44 on occasion in the AM, but it never stays there for more than a moment.
<45v at any time.
Old Jun 3, 2013 | 04:14 PM
Frankenbiker
That's correct. Yours reads "less than 45 volts."
(yeah, you can smack me if you want. )
-blaine
Old Jun 3, 2013 | 04:16 PM
Frankenbiker
Low or old batteries can kill a FICM. While they may crank the engine, the crank voltage drops too low and the FICM self-destructs trying to make up for it.
If your batteries are more than three years old, either take them out and condition them, or better yet, replace them. The FICM is remarkably intolerant of old batteries.
-blaine
Old Jun 3, 2013 | 04:24 PM
mustang_309's Avatar
mustang_309
If my FICM even saw 45 volts I would send it out for some loving. Unless it was due to low battery voltage and the battery problem was corrected immediately and the voltage returned to 47.5 - 48.5 then I may let it go.
Old Jun 3, 2013 | 04:29 PM
Rusty Axlerod
I got ya .
Yup, 45v or less () it's on it's way out, if battery voltage is drooping badly during crank it might "save" the FICM to replace the batteries as Blaine posted above but it's definitely stressing.
Old Jun 3, 2013 | 04:33 PM
utjer's Avatar
utjer
Just replaced my ficm. I highly recommend ed @ ficmrepair.com. Many, many people here have used him. He has different options as far as warrenty and tuning on them. They are plug and play so no need to go to the dealer afterwards for tuning.
Old Jun 3, 2013 | 07:47 PM
Bonanza35's Avatar
Bonanza35
And update in the alternator is also recommended by ED. I believe he recommends the DC power 270 Xl or something. It keeps volts in check at start up even in the cold and makes them live.
dakotajeep
Jan 28, 2012 12:04 PM
King of the Road 04
Nov 27, 2010 02:06 PM
larchy
Jul 28, 2010 11:39 PM
powerstroker100
May 10, 2010 09:59 PM
