Brake System Bleeding
Old Jun 9, 2003 | 09:25 AM
PA F150 4X4's Avatar
PA F150 4X4
I replaced the brake line on the drivers side from the proportioning valve to the frame connection to the caliper.
Can the air in the new line be bled at that caliper and valve connection at that wheel only or does the air travel to other locations?
The only issue is the rusted brake bleeder fittings at the other wheels. I rounded the one off even with a six point wrench and had to resort to the vice grips to get it open.
Old Jun 9, 2003 | 10:41 AM
steve83's Avatar
steve83
New bleed screws aren't expensive, and remember that the brakes are arguably the most critical system on the truck - NOT the place to save a few pennies.
Start by bleeding just at that caliper, but if the pedal doesn't firm up, bleed them all, starting with the longest distance from the MC and working back to the shortest.
