glow plug problem
Old Jun 3, 2013 | 02:06 PM
Danny in Draketown's Avatar
Danny in Draketown
glow plug problem
I have a 1989 f250 7.3 lt diesel xlt lariat esi w/e40d. on the passenger fender the is a relay with 4 terminals on it. 12 oclock and 6 oclock are small terminals 9 oclock and 3 oclock are large terminals the 9 oclock terminal has an 8 ga wire coming right off the battery which is always hot. when I turn the key on should the 3 oclock terminal be hot then also. I believe that the wires to the glow plug relay are attached to that post, as the run via a black and pink wire and then into the tan wire that run to the glow plug relay but it does not activate when the key is turned on???
lancekilgore
Dec 12, 2012 10:43 AM
dad50+
Sep 14, 2012 10:33 PM
hunterguy86
15
Jan 20, 2010 05:30 PM
dbrugger
Jan 6, 2009 07:32 PM
Banshee Ben
Jul 8, 2005 04:29 AM
