Overheating
Old Jul 14, 2002 | 04:34 PM
Toy man's Avatar
Toy man
Post Overheating
During the last month of camping, my F-150 (300 six 5 speed 3.55 rear gear) I've notice it been running hoter and hoter. I put a 160 thermo in it, water seems to be moving in the rad. fan belt ok I run 60-65 mph pulling a 25 ft trailer, when I get into a small town or stop in a rest area the temp gage goes to the "r" on the temp gage. Driving down the highway it runs past the "L"Since I bought the truck in 94 it's never run hot, It's only got 55000 miles on it I put 10w30 oil evefry 3000 miles What should I be looking for HELP Thanks
Old Jul 15, 2002 | 01:02 AM
bigblockfan's Avatar
bigblockfan
Overheating
Is it leaking coolant anywhere? The first thing I would look at is the water pump. Grab the fan, and see how much play is in the pump shaft.
Old Jul 15, 2002 | 01:24 AM
samhihn's Avatar
samhihn
Overheating
sounds like classic symptoms of a radiator flow problem. Either the pump isn't pumping well or the radiator is clogged with crud.
Old Jul 16, 2002 | 02:30 AM
ninjaplumber's Avatar
ninjaplumber
Post Overheating
Tested your FanClutch? On the front of your fan, there is a spring, if you take a screwdriver and unhook it and let it turn back 180 degrees, it will disengage your fan clutch, therefore your fan will be going continuously. If it stops overheating you need to replace it.
Old Jul 20, 2002 | 09:29 PM
Toy man's Avatar
Toy man
Overheating
Thanks for all the help!!!!
I found the radiator was plugged from the bottom up 8".
I put a 4 row rad. in it, runs like it did new.
One helpful hint I learn was wet down the radiator before starting, when the the coolant flows it will dry the fins/tubes no flow stays wet longer.
Again I thank you all for you help
Old Jul 20, 2002 | 10:13 PM
S Casey's Avatar
S Casey
Overheating
