So I have a 1973 Ford F250. I haven't driven it in a while due to getting a new interior installed but I did get significant wheel hop on acceleration. It is the 390/C6/4.10 combo. It does have A/T tires. What is the best thing I can do to glue the rear tires under acceleration? The motor has been liberated of the smog crap but the timing is still retarded. And it has headers
if you really want to plant the rear end you need a antiwrap bar. The problem with leafs is that they literally let the axle twist and then snap back causing wheel hop. if you can weld it is a cheap and easy fix.
yes 1 should be fine. I only run 1 on my rockcrawler and it works great. I used Ballistic Fab's ladder bar bracket (they are local for me but they ship great)
I used DOM tubing and built a slip and twits unit. One piece slides inside the other so no need for a shackle and I like the solid mount at the front. As for length it doesn't matter how long but longer is better. just find a solid place on a crossmember because it will create a lot of force on that long arm. Good luck.
