Electrics
Old May 31, 2013 | 02:49 PM
1948 F1dude's Avatar
1948 F1dude
Electrics
Who knows about amps & volts type stuff.. I have a clock I got from Jegs I want to put in my truck. Directions say 4 amps . I do not burn this one up. How do I get a constant power source 12 volt 4 amps . I had a stock '56 wiper motor once and hooked up 12 volts and it burned up (Too many amps)..... help
Old May 31, 2013 | 03:17 PM
Kurt G.'s Avatar
Kurt G.
For a clock you'll want a battery source from fuse block and get a 4 amp fuse so that it will be limited down to 4 amps. make sure it is wired correctly and you should be good,
Old May 31, 2013 | 03:34 PM
jniolon's Avatar
jniolon
old and in the way
if it is a 12 volt clock you won't burn it up by hooking it to any 12 volt source... thinking it will burn up... the clock will only pull what it needs to operate it properly. Don't know what the problem was with the wiper motor unless it was possibly a 6 volt unit.
I agree with using a 4 amp fuse.... but that doesn't protect the clock... it protects the rest of the electrical system in case the clock shorts out and tries to draw far too many amps ... melting the wiring and possible causing other damage... the fuse only allows the clock to draw 4 amps not prevent the electrical source from pushing more than that to it should it short out for some reason... Batteries don't push amperage into a device it only allows amperage to be drawn from it depending on the needs of the device
and to me that sounds like a lot of amperage for a clock
afa as hooking it up... Kurt told you right... constant 12 volt source (not switched with ignition) inline fuse at 4 amps and either a case ground or a ground wire hooked to chassis ground
later
John
Old May 31, 2013 | 05:16 PM
1948 F1dude
Thanks guys
Old Jun 1, 2013 | 11:57 AM
arctic y block's Avatar
arctic y block
And after sitting for a month and the battery goes dead, ya can blame it on the clock for pulling power all the time. If this truck is not a daily driver than put in a battery disconnect switch or disconnect the battery if it is going to set all winter. Are ya sure it draws four amps? Or is that its max rating? It should draw like 1 amp or less I would think or you are gonna have a dead battery a lot. I just stuck a digital clock with its own battery to the dash with Velcro.
jvmcc
Jul 22, 2016 02:04 AM
jvmcc
Electrical Systems/Wiring
Jul 21, 2016 05:48 PM
j7angus
May 24, 2011 05:37 PM
pjhjah
Oct 27, 2009 01:31 AM
f1fordguy
Jul 19, 2006 04:09 PM
