rear diff
Old May 31, 2013 | 10:54 AM
srisher's Avatar
srisher
rear diff
Hello all,
I have a 86' F260 that im parting out. It has a Dana 60 rear end. I was thinking on replacing the Dana 60 on my 65' F250 with the more modern unit.
Im unsure the gears in both rear ends the tag in unreadable on the 86' and missing on the 65'
My reasoning is use the 86' rear end because changing the breaks dont require removing the axel to take the drum off, (that is what I was told).
what would be the pro/cons on this swap? is it worth the time and money to do it?
Thanks for the help
Old May 31, 2013 | 11:02 AM
rogue40's Avatar
rogue40
I don't know about the 86 but my 84 F250 diesel still required you to pull the axles and spindle nut to remove the drums.
Old May 31, 2013 | 11:11 AM
srisher's Avatar
srisher
ok I never did a break job on a Dana 60 so I dont know they may be the same
Old May 31, 2013 | 12:04 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by srisher
Hello all,
I have a '86 F260 (Type/GVW/MODEL code F260 = F250 4WD) that im parting out. It has a Dana 60 rear end. I was thinking on replacing the Dana 60 on my '65 F250 4WD with the more modern unit.
Im unsure the gears in both rear ends, the tag in unreadable on the '86 and missing on the '65.
My reasoning is use the '86 rear end because changing the brakes doesn't require removing the axle to take the drum off, (that is what I was told).
You have been misinformed.
Please, when asking questions, list all the pertinent info.
AXLE code stamped on the Warranty Plate (1961/79). 1963/79: Riveted on the left door face below the latch. Post what the code is.
1965 F250 most likely will be either 3.73-1 or 4.10-1 as 3.54-1 wasn't available until 1966. 4.56-1 & 4.88-1 somewhat rare.
AXLE code printed on the Certification Label (1980 to date) that is glued on.
1986 F250 4WD could have a Dana 60 or Dana 61 or Sterling 10.25.
1961/72 F100/350, 1973/77 F250 4WD (High Boys), 1973/79 F350: Cab & Chassis, Crew Cabs and Regular Cabs on the 140" wheelbase have 33 1/2" inner rear frame rails behind the cab.
ALL other 1973 and later F100/350's have 37 1/2" inner rear frame rails behind the cab. So, you cannot swap rear axles without changing the spring hangers and shock mounts.
There are other factors to consider, the difference in driveshaft lengths due to different wheelbases, different companion flanges.
You need to get ahold of FTE member "Squire" Don (camperspecial65) who lives nearby. Don knows these trucks better than most. rott_weiler33@yahoo.com
I sent you an email with Don's cell number.
Old May 31, 2013 | 12:24 PM
srisher's Avatar
srisher
Thanks again ND you sir are always a wealth of knowledge and help.
sadly the warranty plate on the 65' and the sticker on the 86' are missing so I dont have that info available.
It sound like it would be the best to let it be as is.
Thanks,
Sam
Old May 31, 2013 | 12:41 PM
NumberDummy
The big dummy just returned from a two week AK cruise/tour. See the last two lines in post 4.
Old May 31, 2013 | 12:44 PM
srisher's Avatar
srisher
Thanks again ND
Old May 31, 2013 | 12:51 PM
netstores's Avatar
netstores
Bill:
Can you give me a call, I need your help on a stolen trailer to identify the Ford Trucks
VIN number from DMV.
You can call me 541-501-0225. Thanks
Adam
Old May 31, 2013 | 01:41 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I just got back from a one week cruise to Alaska. Ketchikan, Juneau, Skagway. Not too bad. Where did you start from? Cali? Two weeks sounds brutal.
Old May 31, 2013 | 02:10 PM
NumberDummy
Holland America M/V Zuiderdam: Vancouver-Juneau-Skagway. WP&YRR Skagway to Fraser BC, then motorcoach to Whitehorse-Dawson City-Tok-Fairbanks. AKRR Fairbanks to Denali, then Anchorage.
2nd AK cruise/tour, 5th AK cruise since 2004.
Old May 31, 2013 | 02:26 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Sure. I saw the Zuiderdam parked with us at Juneau and Skagway. I was on the Celebrity Solstice. We got up to the end of the Tracy Arm Fjord and got a good view of a glacier there. Cool stuff. Actually cold stuff. Dang, if I'd known I'd have tried to contact you. This was the Zuiderdam in Juneau, I believe. Although there were two Holland ships there at the same time so this might be the other one.
Old May 31, 2013 | 02:34 PM
NumberDummy
Juneau May 20th: Pictured Holland American ship was already there, abaft (to the far right-out of pic) was a Princess ship. Zuiderdam sailed in at about 1:30 PM, berthed at faaar right (way out of pic).
Celebrity arrived just after Zuiderdam, watched as guests were tendered to dock.
9/2006: Took a repositioning AK cruise on the Celebrity "Summit" / Vancouver-Ketchikan-Juneau-Skagway-Icy Point Strait-Hubbard Glacier-Sitka-Victoria-Seattle-San Francisco-Catalina Island-Los Angeles.
Old May 31, 2013 | 03:08 PM
TA455HO's Avatar
TA455HO
Lead Gopher
That's right. Zuiderdam was to our stern. And the Princess Star or somesuch was between the two Holland ships. Those tenders were a bit of a wait, but not too bad. Here's a shot of all four looking outward from town. You can see the tenders next to the Celebrity and one halfway between the ship and the dock. Our whale watching tour was cancelled due to high waves so we just wandered around Juneau. Not a lot of excitement there.
Old May 31, 2013 | 03:21 PM
NumberDummy
We had verandah (balcony) #5081, starboard side, just above lifeboat #7.
Ashore next to the first dock is a memorial to the USS Juneau (CL52), an anti-aircraft light cruiser sunk off Guadalcanal November 13, 1942.
All 5 of the Sullivan brothers perished. In 1943, the destroyer USS The Sullivans (DD537) was commissioned.
Old May 31, 2013 | 03:45 PM
Blackwaterforge's Avatar
Blackwaterforge
You will have to change the location of the spring perches.
The later rear end should be wider and be closer to the width of the front end on your 66.
No more often than you will have to service the brakes pulling the axles is not a big deal.
I had a 65 F-250 a 88 F-350 a 95 F-350 and now a 66 F-250 and I had to pull the axles on all of them to service the brakes.
