72 f100 vibration
Old May 30, 2013 | 12:46 PM
jeepunit's Avatar
jeepunit
72 f100 vibration
Ok so I bought this truck on a whim. Guy said it needed a harmonic balancer( I replaced) still the vibration. Well figured it was the file plate (c4 tranny) it was fine right weight. Torque converter was good. Maybe it was the timing but no that was spot on to chiltons manual for this 302. Spark plug wires are right compression is strong vacuum lines are all good except the vacuum tree has a few plugged holes. I called the previous owner and he said he rebuilt it 6 months before I bought it and he had put a bigger crank and heavier rods but stock size pistons valves ect. Could this be the problem I'm boggled please help.
Old May 30, 2013 | 02:43 PM
HIO Silver's Avatar
HIO Silver
More info needed....Is this an engine vibration or a driveline vibration??? Meaning, idling at a standstill or while going down the road?
Ya could be barking up the wrong hole.
Old May 30, 2013 | 04:10 PM
bradb2230's Avatar
bradb2230
Ask the previous owner if the rotating assembly was balanced during the overhaul. Ask it just like that. If he did he will know what your talking about, if he hesitates then he didn't. If he didn't I would get out from under the truck fast, or plan on replacing the engine soon.
Old May 30, 2013 | 06:56 PM
jeepunit's Avatar
jeepunit
It was balanced and the vibration is coming from the engine or tranny it vibrates in park while driving smooths out at higher speeds but vibrates at high rpms
Old May 31, 2013 | 05:20 AM
elgemcdlf's Avatar
elgemcdlf
Did he have a larger cam installed?
Old May 31, 2013 | 06:11 PM
hd97fxdc's Avatar
hd97fxdc
The previous owner may have put a new model crank in it, the old ones prior to 1980's (can't remember what year exactly) are 28.8 ounces of unbalance and newer model cranks are 50 ounces.
Old May 31, 2013 | 06:19 PM
jim collins's Avatar
jim collins
I'm thinking the same as "hd97fxdc" , i believe 81 was the 50 oz. balance. I bought what was supposed to have been a 79 302 and had the same problems you are having , turns out my 79 was an 81 . Changed to 50 oz. flywheel and problem solved .
utahratrod
Sep 7, 2006 06:09 PM
302V8
Jan 24, 2005 01:31 AM
khendrix
2004 - 2008 F150
Nov 2, 2004 06:59 PM
dand98625
Jan 13, 2004 02:47 PM
94van
Dec 23, 2001 08:34 PM
