XCab question
Old May 28, 2013 | 12:16 AM
Monte1go's Avatar
Monte1go
XCab question
Is it at all possible to set a extended cab on a longbed frame with a 6' bed to make an extended cab short bed bullnose?
Old May 28, 2013 | 07:58 AM
parkerparkerm's Avatar
parkerparkerm
You'll have to shorten the bed or extended the frame for a perfect fit
Old May 28, 2013 | 08:12 AM
MavSprint's Avatar
MavSprint
Check out the dimensions in the '81 Ford truck brochure. Might give you some ideas on how to approach it. 1981 Ford Pick Up / 09.jpg
Old May 28, 2013 | 09:31 AM
Franklin2's Avatar
Franklin2
Can't do it unless you use a body lift. The frame kicks up after the cab, and the kick-up is further back on a extended cab.
86f250-rs
Sep 10, 2015 11:35 PM
doinfroggy
Jan 9, 2011 08:03 AM
tahleel
Jan 24, 2009 08:37 PM
Acrasia
Feb 28, 2003 06:03 PM
Truckslayer84
Jan 25, 2002 07:19 PM
