learn from my mistake - use RTV
That was before I owned a torch when I was still in dummy land, but I have a couple of them now. Accumulated a lot of tools in the last year. I need a bigger tool box. Bought me a set of offset wrench heads a few weeks ago to get to an exhaust bolt that was in a really tight spot, and man did those come in handy today with track bar. Tight squeeze getting the passenger side bolt out and clearing the tie rod, offset did the trick along with a "floor jack" acting as the muscle to break the bolts loose.
Well I couldn't find the "Right Stuff" at the auto store so I went with black rtv. FAIL. Still leaking like crazy. Getting pretty fed up with it at this point, so I'm just gonna take it to a shop and let them figure it out. Am I safe driving with no fluid in the front axle if my hubs are unlocked and I'm in 2wd?
I would think you would be fine just be sure your hubs are not locked and you are in 2WD. You must have a bad cover, if it's not flat is the only way RTV not going to seal it, you sure you don't have a stripped bolt? Did you let it set up for a bit before installing then wait before filling?
on
( I was typing at the same time)
Just a note with the "Right Stuff" no need to let cure a little. Just put it on and bolt it up add fluid and drive away. Its made different from regular silicone. As long as your diff or axles aren't turning no lube in there is fine because nothing is turning...Just make sure the axles are not turning. Hubs unlocked.
45 minutes?
How long did you wait for the strait RVT to dry?
The least I normally wait is 14 hours.
I'll put in another plug for the Right Stuff. I don't even bother with regular RTV anymore, it's the Right Stuff or nothing. I keepa can or two of it in the garage at all times. If you can't find it, you're not looking very hard. I think just about every auto parts store on the planet carries it, and I think I've even seen it at Walmart.
You could do it that way, but you'll never get all the old fluid out, you can't clean out any crud that may have settled in the bottom of the pumpkin, and you can't inspect the condition of the gears.
#28
I bought a can of that once. It did work fine but was just to expensive for my taste.
And replace the rusty pan cover.
#30
