Aerostar Ford Aerostar
voltage regulator?
Old Jun 8, 2003 | 04:18 PM
papa_g's Avatar
papa_g
Exclamation voltage regulator?
My problem is my 92 3.0L is showing voltage variations at different speeds. Big variatons. At a dead stop all is fine 14 volts. When I take off the voltage goes up off the meter. At 35 mph steady, all ok. Mild excelleration and voltage drops to 8 or so. Now if I give the gas it jumps up again. I think it would be a voltage regulator issue. If it is where is it? I was told it may be built into the alternator which is less than a year old.>>>>>>>>>>Help!!!! I use mine for a work vehicle. It has only 138k miles. watcha think
