battery light staying on
Old Jun 8, 2003 | 04:18 PM
wsims's Avatar
wsims
Unhappy battery light staying on
After replacing alternator , finding out there are two fuses for alternator (one in engine compartment blown). Checking voltage running and not (12.8 not running 14 when running) . The battery light stays on? I have a 96 ranger , can't find wiring schematic.
Please Help.
Thanks in advance!!!!!
Old Jun 8, 2003 | 09:39 PM
Franklin2's Avatar
Franklin2
You have a later model, so I don't know if you have an alternator with a intergral regulator, or the system with a seperate reg. If you have an integral reg/alt, and the wires are on right, then the store may have given you a bad alternator. Believe it or not, this happens alot. If you have the seperate reg, then the reg sounds bad. It's the regulator's job to decide if the alternator is putting out, and turn the light on or off. Yours is charging, so the light should be off.
Old Jun 9, 2003 | 12:19 AM
wsims's Avatar
wsims
Thanks Dave, Second alternator, it appears to be working correctly 14v when started . The regulator is internal . Do you know if there is a relay for this the gauge is showing normal?
Thanks so much it is very helpful at least I know where the signal comes from.
Thanks again!!!!
Old Jun 9, 2003 | 12:25 AM
Mil1ion's Avatar
Mil1ion
Don't go by Ford gauges .
Get a multi-meter and do a real test
{with turning accessories on & off while checking the meter}
Old Jun 9, 2003 | 12:30 AM
wsims's Avatar
wsims
Thanks haven't tryed with load .
Thanks again!!!
Old Jun 10, 2003 | 08:44 AM
wsims's Avatar
wsims
Smile battery light staying on
Thak everyone for there input. Had someone else check the charging system checked good. Light still on . Drove to work light on . Good news now , on the way home went to get on highway Chevy cut me off gunned the truck light flickered then went off!!!!
Converted chevy guy. This sight is great Thanks so much . I even got help on dome light staying on . Delete this message if needed I'll be back maybe to pass on information next time.
Peace and Thanks again.
wsims@cowtown.net
